Question about Computer, Chip, Cruise Control for Toyota RAV4
I have a 4-cylinder 2002 Toyota Rav 4, all wheel drive. When i try to engage the cruise the light comes on, but when i release the button at the desired speed the car declearates, and the cruise light blinks. I don't have a shop manual, and would appreciate any help in solving this problem. Larry
    Sergeant:
  • 243 Answers
My standard answer for this type of question is that you should purchase a haynes or chiltons manuel for your vehicle, you will find a lot of very good info about many things as well as tips for repairs that will save you time.
These can be purchased from most auto supply stores or for a little less money on ebay.
Posted on Dec 02, 2014
My 2009 Toyota Tacoma 4 wheel drive 6 cylinder cruise control does not work
check fuses and relays --have vehicle scanned if theirs a fault pending most cuise controls wont operate most auto stores offer scan for free if good stat looking at switch and harness
Aug 01, 2016 | Toyota Cars & Trucks
How do i remove the ignition cylinder on my 2002 Toyota Rav 4 without the key?
from another post, psoted by James Allmond
How to remove ignition cylinder from Toyota Camry 1993
Here are step-by-step instructions for the removal and re-installation of your ignition cylinder on your Toyota. Hope this sheds some light on the subject and solves your problem. Have a great day!
  1. Disconnect the negative battery cable. If equipped with an air bag, wait at least 90 seconds before working on the vehicle.
CAUTIONSome models covered by this guidemay be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in .
  1. Remove the lower steering column cover. Unfasten the ignition switch connector under the instrument panel.
  2. Remove the screws which secure the upper and lower halves of the steering column cover.
  3. Turn the lock cylinder to the ACC position with the ignition key.
  4. Push the lock cylinder stop in with a small, round object (cotter pin, punch, etc.).
On some vehicles, it may be necessary to remove the steering wheel and combination switch first.
  1. Withdraw the lock cylinder from the lock housing while depressing the stop tab.
  2. To remove the ignition switch, unfasten its securing screws and withdraw the switch from the lock housing.
To install:
  1. Align the locking cam with the hole in the ignition switch and insert the switch into the lock housing.
  2. Secure the switch with its screw(s).
  3. Make sure both the lock cylinder and column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
  4. Install the steering column covers.
  5. Connect the ignition switch wiring.
  6. Connect the negative battery cable.
source
How do remove the ignition cylinder on my 2002 Toyota Rav 4 without the key
Jul 28, 2016 | Toyota Cars & Trucks
What causes Toyota Rav 4 2002 have one catalytic converter overheat? Replaced the entire assembly and new sensors. when started in a couple of mins was doing the same thing as old converter running on...
You converter is not the reason for misfire,Bad spark or leaking injector will release row fuel in converter and after burn and glow red hot. remove all spark plugs an look for one is black. or wet . replase plugs with DENSO or NGK inspect the wire for burn blue marks on the side or replace the injector if fluted cylinder.
Good luck
Mar 01, 2015 | 2002 Toyota RAV4
Toyota RAV 4 2002 (Auto). Rear off side wheel does not rotate when drive is engaged, (it just drags). With rear wheels elevated and neutral selected, rear near side drive shaft will rotate but rear o
you should check the park brake cable please note that the rav4 uses a disc brake for driving but has internal brake shoes for parking/emergency braking they are located insider the disc
Sep 29, 2014 | 2002 Toyota RAV4
My 07 toyota rav 4's engine and four wheel drive
I doubt it.
Did you check the computers for trouble codes ?
Aug 03, 2012 | Cars & Trucks
My four wheel drive won't engage 05chev pickup1500 non HD 135000
4x4 on the floor or push button ? If push button, then it could be the solenoid.
Cruise could be switch, loose wiring.
Feb 04, 2010 | 2002 Chevrolet Silverado 2500HD
How do you use cruise control?
Should be a operater manual with car, if not, the left side of steering wheel is a small handle. On the end is a button. In the middle is a "resume" switch that is pussed with your thumb. While driving push the end button, the car should engage and power without your foot on the peddle. To go faster push the middle switch with your thumb toward steering wheel and that will increase the speed. When you put on the brake the cruise control should dis-engage. Need to practice with this on a safe road. You may need to go at least 40mph for it to operate. When the cruise is engaged a dash light should come on saying "cruise" - Good luck
Oct 15, 2009 | 2002 Chevrolet Cavalier Coupe
2002 Dodge Dakota
well because the abs light indicates a problem with your anti-lock braking system you need to find out why it is on.... keep in mind one quick way you would disengage your cruise is with the brake pedal.
under the hood is a fuse panel (often located near the battery) ... see if there is a relay in the for your cruise... replace that.
Robert
Dec 17, 2008 | 2002 Dodge Dakota Club Cab
Toyota rav 4
I work for Toyota, and I will be glad to provide you with the actual answer:
The RAV/4 product is available in two models, a 4WD model and a 2WD model.
The difference between the two is on the 2WD model, there is no driveshaft going under the vehicle to the rear wheels, and no rear differential. There is no "RAV/2"; both models are called RAV/4's.
There is a lot of common confusuion about how the 4WD works. It is full time 4WD. In other words, it is always in 4WD. It does not "kick in/kick out/automatically engage", or anything like that. It is 4WD all of the time. But, when I say "4WD", that is sometimes mistaken for "all wheel drive", and, in this case, the RAV/4 is not "AWD". What this means is that if you raise the RAV/4 up on a lift, and put it in gear, 1 rear and the other side front tires will spin. True "all wheel drive" would have ALL 4 wheels spinning. This is not the case with the Rav/4. What the RAV does have, making up for not having "True AWD" on the 5 speed model, however, is a switch that locks the center differential in the transfer case, which, when engaged, applies a method of "locking" the 4WD system for maximum traction, but it is still not AWD. The automatic version doe not have this ability.
The last "true AWD" vehicle for purchase was a 1970's International Scout.
If you are considering purchasing a RAV/4, that is a very good investement. They hold their value quite well, and are virtually bulletproof; I do not make any "money" off my RAV/4 customers...
Just "gas station work". Very nice cars. I hope that this helps you, please feel free to comment back with any otherr questions...Glad to be of assistance.
Toyota Ed
Oct 17, 2008 | 2002 Toyota RAV4
Computer, Chip, Cruise Control for Toyota RAV4 Logo
100 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
