Question about FUJIFILM A220 Digital Camera
How do i get the pics from the camera to my computer? I know I remove the card, then where do I put it?
  • 66 Answers
You can buy a multi card reader and place it there.
Posted on Mar 28, 2011
Digital camera about 4 years old, take pics, they are on screen when reviewed, but when I put SD card in computer they do not come on the computer. Couple of days later, took more pics, put SD card in...
Possible that the SD card is having errors, So take a scan on the card and confirm. Also check the card on another PC to confirm if there are images on the card. If not there can be errrors in the camera. It will be ideal to have another SD card ( borrowed) to be inserted to the camera to confirm.
May 17, 2011 | Panasonic Lumix DMC-LZ3 Digital Camera
I need to know how to put the pics on my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 03, 2010 | Olympus SP600UZ Digital Camera
How can i transfer my pictures to the computer from my camera?????????? thanx
It is not possible to give specific help without knowing the make and model of your camera.
However, most people find it convenient to simply remove the memory card from their camera and put it into a card reader attached to their computer. The card will then appear to be a removeable disk drive, and you can simply drag the pics across to your desktop. This will work with almost any camera that uses a memory card.
Nov 09, 2010 | Cameras
Photos downloaded to computer from picture card.when card put back in camera showed card set up Power off ...
When you removed the card from the computer, did you: A. forget to use the "safely remove hardware" function B. delete the pics using the computer instead of the camera Either of these could cause your problem. If the pics are safely on your computer, I suggest you format the card in the camera.
Oct 14, 2010 | Olympus Camedia C-310 Zoom Digital Camera
My ZD710 will not recognize any cards I put in. The cards have pics on them and I can see them when I put the cards in the computer. I even bought a new card and the camera will not recognize it.
If you put a card into a computer and then remove it without using the "safely remove hardware" function, or you use the computer to change something on the card, your camera will no longer recognize it. You need to download the pics from the cards and then, format them in the camera.
Aug 19, 2010 | Cameras
After deleting photos from the memory card, it now says "card not initialized", when put back into the camera, none of the functions seem to fix it, can you help?
If your pics are safely on your computer, follow these rules: 1. Never erase pics using the computer...always use the camera. 2. Never remove anything from the computer USB ports without using the "safely remove hardware" function. 3. Now, your card needs to be formatted in the camera.
Aug 10, 2010 | Fuji Finepix A510 Digital Camera
Transferred pics from computer to card and the camera will not display them - all are jpeg just like what the camera takes. These were from the camera but I wanted them back on the card also.
once out of the camera & deleted form the card, the camera will not display any of the images because it does not have that function. even jpeg images being the same format cannot be viewed.
Apr 21, 2010 | Kodak EasyShare One Digital Camera
Memery card into computer but no pictures
I posted the info below for someone else with a similar problem. I hope it is helpful. Let us know if it is not, Andy If you can remove the memory card and put it into your computer it will see the card. If it does not automatically give you an optoin to veiw the pics. Go to:Start>Computer>expand computer in left pane(your card will have a drive letter and it's name after it i.e.E:\canon sd card.>select your card and look in the different folders, it's usually in DCIM>101 or other ### folders.
Comments: Sep 09, 2009- can you cancel the format. open the folder with pics, then copy them into your documents or picture folder on your hard drive? I have seen these cards do some strange things.
If you still have trouble try rebooting your computer. After restart insert card and try again.
FYI; always let your camera finish processing a picture you have taken before turning it off & never remove the card while camera is on. If batteries2.gif die while processing a photo you can risk losing all pics on card. So download often and replace batteries before they die completely.
Andy
Nov 09, 2009 | Cameras
I uploaded pics from my computer onto my Camera SDPhotosmart M537
If I understand you correctly, you put pics onto the SD card using the computer, then put the card in the camera and now can't see the pics? Is that correct? The camera won't recognize the pics because it uses a different recording system than the computer. Now if you want to take more pictures using that card, you will need to format it in the camera first.
Oct 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Dont know how to get pics out internal memory
Actually, you can do it without the cable.
You need to have the card inside your camera with at least ONE picture. Hit play. Press menu. Scroll down until you see COPY and then choose "Internal to SD Card" Hit All Frames. Hit OK. Done.
Cheers,
V+
May 16, 2009 | Fuji FinePix J10 Digital Camera
FUJIFILM A220 Digital Camera Logo
24 people viewed this question
Top FUJIFILM Cameras Experts
Steve
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
