Question about Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun
I cant the staples to staples anything - Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun
I have 3 of your electric staple guns and they all stopped working after a short period of time.Had the staple guns quite awhile and put away.Is there anything you can do to help?
you do not have any staple guns from fixya site as we do not make sell or have anything to do with merchandise
make your comments about quality to the manufacturer web page
Jul 17, 2017 | Electric Tools & Hardware - Others
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Surebonder 4.8 v cordless stapler
with mine there is a fine spring on the plunger which holds the staples in which i restretch every now and then you could also try checking for jammed staples and putting one or two drops of oil on the shaft that pushes the staples down after the oil operate afew times empty of staples see if this helps bestaluck glenn
Oct 26, 2008 | Tools & Hardware - Others
Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun Logo
Top Powershot Tool Company Tools & Hardware - Others Experts
john h
Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
