Question about Whirlpool ED2GHEXN Side by Side Refrigerator
Ice maker doesn't work. How do I check to see if it's the actual icemaker or the water inlet valve?
    Sergeant:
  • 176 Answers
Go behind the fridge where the water comes into it. the hose should go into a valve. if you have water and ice in door. there will be two hoses coming out the other side. what I did was find the hose that goes up to the ice maker and unhook it and there was no water coming out while it was trying to make ice. that valve is replaceable and are even on ebay. on mine the water worked in the front door, but ice maker did not. I think the valve is common problem.
Posted on Mar 28, 2011
  • mylit Mar 28, 2011
    So what you are saying is, if the water is not coming out then it's the valve? And if the water IS coming out then it is the actual icemaker?
  • Ricky brashear
    Ricky brashear Apr 07, 2011
    yes
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
U line ice maker, the water doesn't shut off after filling the tray.
Change the water inlet valve if it is off and water continues to bypass the valve when off...Sea Breeze
U-Line Refrigerator Parts
Water Inlet Valve 2552A
Mar 25, 2013 | U-Line Icemaker
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Refrigerators
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our icemaker does not fill with water
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not getting water
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Aug 30, 2009 | Refrigerators
My refrigerator does not make ice. I have to manually poor water in the icemaker to make ice.My water dispencer works but no water refills ice maker
Hi, The first thing you want to check is the inlet tube where the water spills into the icemaker. Most of the time, the tube gets plugged with ice preventing the ice maker to fill. If there are no blockages, check the inlet valve on the ice maker side of the valve. You can test the valve when the ice maker cycles and see if it is getting 120V. If there is voltage and the solenoid does not engage, replace the inlet valve.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Amana ASD2625KE Side by Side Refrigerator
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
