Reset button comes on after heater is running
  • 3,289 Answers
A reset button on any heater has to do with either an over-temperature or over-current condition. Since you didn't go into detail, I don't know if your "heater" is a quartz type space heater, electric water heater, or something completely different.
Over-temperature
means that the device is getting too hot - and that the thermostat control is not operating as designed, failing to interrupt power to prevent overheating. The reset is separate safety device, and is designed to shut the heater down to prevent burns, fire, etc. Once operated, it stops power until it is manually reset.
An over-current device is an electrical device that works very much like a circuit breaker. If the heating element or associated wiring has been damaged, resulting in it drawing a larger amount of power than the wiring has been designed to carry, this device will open to interrupt the power to the device or appliance until manually reset. Any electrical device or appliance, when operated in such a way that allows it to draw more power than the wiring can safely handle becomes a fire hazard. The wiring or cord will heat up and if hot enough for long enough time, can cause the insulation to melt or burn. This creates a shock and fire hazard.
Any device or appliance that has a reset switch that opens more than once under normal use and conditions should be removed from use until it can be inspected and repaired.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Mar 28, 2011
    Sergeant:
  • 176 Answers
This means that the heater is drawing more current than it is designed for. it could be a bad heating element that is shorted. the power cord could be shorted or last the reset button could be bad.
but usually it is something shorted.
Once the heater reaches the set temperature at the thermostat it shuts off.the flame goes out but the pilot light stays on. the heater will not kick back on automaticaly when it gets cold however it will...
you will have to look into why the unit is tripping and needs resetting. Heaters usually have a fan delay, meaning that when the heat is satisfied, the fan continues to run for about an minute. If not, it could cause an overheating issue and trip a safety. Look for that to start with.
Aug 05, 2017 | Williams 3003622 Ceramic Wall Mounted...
Need to reset heater after unplugging while power was on
Somewhere in the heater there is probably manual reset high limit switch. That kicked out when it shut off hot and did not have time to cool down. You need to find it and there will probably be a little red button in the center. Push in the button till you hear a click and you will be good to go.
Nov 13, 2009 | HeatSafe MN300TPA Heater
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Fan started to run continuously and now heat will
Check the burner reset button on the unit. Has it tripped the red button?Push the reset only once and if it doesn't run after pressing it once then call a technician to look at it. Good luck
Apr 25, 2009 | Heating & Cooling
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have an R50 Reddy heater. It will start and run and heat for about 4 mins, then it shuts down. Then I push the reset button and it will run approx. 5 soconds then shut down. What do I do and will it be...
If the heater runs good & smells good while its running, but shuts down for no apparent reason, then most likely, you have either a bad Safety Control HA3003 (reset) or a bad photocell HA3019.
But, don't rule out simple problems like:
(any of the following can cause a flameout condition, in which case the photocell will shut the unit down. This is where trouble shooting comes into effect).
  1. loss of ground at the Ignition Control (transformer)- not screwed down good
  2. restricted fuel fulter
  3. restricted or worn nozzle
  4. air pump pressure not set to specs
troubleshooting tips
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
