Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How do i take the filter apart to clean it - Hoover U6630-900 WindTunnel Bagless Upright Vacuum
My dyson animal sounds like something is stuck and flapping in the hose,filter, etc. I have taken it apart and I can not find anything. Have you had anyone else experience this issue?
try changing the filter. could be it is coming apart and making the noise. Also sometime these hoses will tear on the inside (lining of hose) and make a flapping or knocking sound. Check the hose as well.
Dec 06, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
How do I take it apart for cleaning and filter replacement?
have to locate where the filter compartment is and replace filter dont know what kind of vacuum you have to be specific
Feb 16, 2011 | Vacuums
I've been very happy with my Pronto 2 in 1 until recently, when it doesn't seem to "****" very well. I've cleaned the filters, etc, and the motor sounds fine. Any suggestions?
Did you check the smaller filter inside the main filter? The main filter comes apart to reveal a smaller filter inside the main filter. This needs cleaning also. If you have found and cleaned that one also. Check the Hose at the bottom for restriction. Thats about it.
Jan 09, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
My Bissell will not **** up pet hair or dirt
Dirt hair and such will build up in the hoses of that vacum. Take them apart stretch them out and run something through them to make sure they are clean.
The other problem is the filter in the bottom of the cup. At least on some models there is a filter that gets totally pligged with dirt and dust. Take it apart, wash it out and them put everything back together.
Heatman101
Mar 21, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
43 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
