Question about Bosch Ariston GL6-plus GL6+ Point-of-Use Electric Mini-Tank Water Heater...
Ariston GL6 less than two years old. Water does not get hot.
Troubleshoot Ariston GL6 6-gallon
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
I have a new Ariston combin boiler heating working but not getting hot water can you help please
Passable blockage in the water section But I would call back who installed it as there is a years guarantee on the boiler
Mar 14, 2018 | Water Water Heaters
How to remove shipping plug from pressure valve opening
If plug is over the valve threads, maybe you can slice it with knife.
If plug is inside the TP valve, then maybe you can put in a screw and pull it out? Or insert small screwdriver and see if you can wedge it out?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Mar 20, 2015 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
We have an ariston pro pi water heater and water is dripping all over from the bottom. How do you drain this? It is less thasn 5 years old
The tank is drained by removing tank, and using hot water outlet as a drain.
Under-counter tanks are not made with thick steel hull that adds cost and weight to product.
Water heater can rust out quickly if anode rod is not checked and replaced each year.
Anode rod depletion is faster if home has water softener.
All tank-type water heaters have replaceable anode rod that protects tank from rusting, and most water heater manuals include general description of anode and maintenance.
http://waterheatertimer.org/Replace-anode-rod.html#ariston
Rusted water heater must be replaced.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Sep 06, 2011 | Bosch GL4Ti Ariston Pro Ti Electric...
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
4) Information on anode rods
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
Bosch GL4ti Ariston water heater - have no hot water is it worth fixing or should I replace? Also, is the reset button different from the on/off switch?
Check if unit has power to the plug. If so, could be bad heater element or bad thermostat. Also could be reset button on thermostat and yes, the reset button is different from on/off switch. Element about $38, thermostat about $30 from www.plumbingsupply.com
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
PlumbingSupply.com has the Ariston repair parts that you need.
ariston-gl2546components.png Diagram # Model # Description Price & Quantity 2 570241 Anode Rod for GL6 and GL8Ti $13.99 2 574305 New Style Anode Rod for GL2.5 and 4.0 $12.95 3 994147 Element Gasket $11.95 4 994140 Element Locknut - 4 Each Req. Per Element - sold each $2.99 5 994103 Element for GL2.5 and GL4.0 $37.95 5 994104 Element for GL6 $39.97 11 65105602
old #994062 Thermostat for GL2.5 and GL4.0 $29.52 11 65150322
old #994102 Thermostat for GL6 $32.57 GL25-4KIT Element, Element Gasket and Anode Rod Kit - For GL2.5Ti & GL4.0Ti $47.65 GL6-8KIT Element, Element Gasket and Anode Rod Kit - For GL6 & GL8Ti $48.65 Note: If you don't see your number unfortunately it is no longer available
Feb 02, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Bosch Ariston GL6-plus GL6+ Point-of-Use Electric Mini-Tank Water Heater... Logo
258 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
