Question about LG Refrigerators
The technician replaced a fuse on the computer board on the back of the fridge. It's been working for 48 hours now. He called to say he needs to replace the complete board for over $500. Does this sound right?
  • kngolden Mar 28, 2011
    Thanks. That was my thought, but I didn't know if I was missing something.
    This is very helpful. He didn't mention the board being damaged, and the refrigerator is cooling so I will follow your advice.
    Genius:
  • 1,400 Answers
Hello
When he replaced the fuse on the board did he say the board was damaged? The fuse is there to protect the board from damage,so the fuse blew and did its job.
Normally if the board was damaged you would not get cooling at all,so i dont understand why he wants to replace the board.
Politely explain the frige has been fine for 48 hours and you would like to see how it will be in a couple days before you commit to a new board.
Thanks and good day.
Posted on Mar 28, 2011
Fluctuation of temperature GE Profile
g.e has mother boards or computer board in them located on the back outside wall,your board is on the top left,part number wr55x10942,everything on your machine runs through that board,also look at the evaporator coil where the thermostat is,there's a sensor on the top of the coil,it looks like a white bullet,if there's a black ring around it where the wires connect to it you also have to change that too.wr55x10025.go here and look at picture,if your board doesn't have all the relays like on this board then you don't have the updated board
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075the new board has all 7 relays and is the newest board.hope this helps and good luck with it.
Sep 12, 2012 | GE Refrigerators
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
The fuse in my LG refrigerator burned out and i have had the hardest time tracking down a new fuse. The fuse is soldered to the circuit board and rather than pay $180 for a new circuit board with the...
Radio Shak had it. I just did the same thing with mine and figured id try and give it a go myself. Turned out, $20 at Radioshak for a solder gun, fuse holder, new fuse and an hour of my time was worth it.
The difference between a "Fast acting" and "Slow burn" (also known as Time-Delay fuse) is one is for a resistive load, and the other an inductive load. Resistive loads are like lights and circuit boards, where the amperage is relatively constant. Inductive loads (time-delay) are motors, things that require a large in-rush current to get moving like the compressor on your fridge. Hope this helps.
Feb 21, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Have older machine always worked with no problem ....it is and FandP Intuitive top load.. today put in light load started off machined filled and stopped....now nothing is happening not even any lights....
If machine is completely dead ie no lights, then you probably have a faulty motor control module (main power board). These do not have any replaceable fuses, requires new module. Note- fault could be with another part of machine, which has caused module to fail eg faulty drain pump can blow control module. All other components need to be testedd before module is replaced, preventing a new module from blowing due to a fault elsewhere. These can be quite a complex machine, and not really easy to fix by untrained persons. Recommend calling service technician
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Jun 07, 2008 | Refrigerators
Samsung american style fridge freezer power loss after internal light blew
try to unplug for 2 min and plug back in to reset the unit otherwise sounds like you cooked a board
May 20, 2008 | Refrigerators
No coldness
There could one of 3 separate problems going on but without fully knowing what's going on, I can't exactly tell you what to look for.  You will probably need a qualified LG technician to see what's going on.
May 05, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Clicking
This unit, I believe is a piezo electric cooling/warming unit. It's possible that after or during your defrost, the control board was exposed to excess moisture... whether by condensation (sweating), evaporation or direct contact with the melted water. In this case, if you plugged the unit in before allowing sufficient dry time, it would have shorted your control board. Possibly allow the unit to dry (unplugged) for 24-48 hours and retry. If the same symptom occurs, replace the control board.
Jul 27, 2007 | Max-Fridge STC55926 / STC55927 / STC55928...
Refrigerators Logo
284 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
