Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
I have a 5-6 year old Amana bottom freezer model number ABB2224DEW. After researching the "buzz-click" noise and having it get progressively worse to the point where it was doing it every few minutes and the fridge and freezer were shutting down, I took out the relay and capacitor. Can someone please advise where to order the correct part from? Also, should I replace both parts, or is the relay enough.
  • 57 Answers
Generally the capacitor doesn't need to be replaced. I think that this part number contains both. 67005560. Est.$32.00. Any appliance repair parts house. I want you to look at the label on the compressor. Does it have a picture of an Indian that says Tecumseh? If it does, don't waste your money on the part. Put it towards a new refrigerator. Sorry.
Posted on Mar 28, 2011
Testimonial: "It is a Tecumseh compressor. Are you saying that I should not even order the part because is won's fix this compressor problem?"
  • 1 more comment
  • jmcmahon310 Mar 28, 2011
    " It is a Tecumseh compressor. Are you saying that I should not even order the part because is won's fix this compressor problem?
  • Greggmark1 Mar 28, 2011
    You can try it. It might run for a while. Just google Tecumseh compressors. In 09 I replaced 50 of them.
  • Walter Kunesky
    Walter Kunesky Apr 25, 2011
    When you change any start assist parts you should always change all the parts. start cap, run cap, start relay. There is other reasons why the start parts are going bad not just the compressor is faultly. Short cycling has a lot to do with it and also problem in pressures equalizing at shutdown can cause problems. Instead of dealing with a parts changer try finding someone that knows service. hope this helps. thank you. wally.
Our amana refrigerator is making a noise, a hum and then a "click". The freezer is no longer working and the fridge part is no longer cold. It's a 2004 and we don't know whether to get...
It sounds like you are hearing the overload on the compressor closing. When the overload closes the relay tries to start the compressor (that might be the buzzing sound) and if the compressor doesn't start the overload opens and turns the compressor off. You will need to replace the relay on the compressor.
Jul 31, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have an Amana fridge model number abb2224dew. The compressor is very hot and the relay/capacitor is buzzing/clicking. The compressor will not startup. What is causing the compressor to heat up and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have a three year old Amana bottom freezer double doors 25 cu ft. The freezer is working fine but the fridge is not cooling at all. I tried defrosting had it unplugged for two days. Tried cleaning the...
There is an evaporator fan locateed inside top of the freezer compartment. It is normally hidden behind a plastic cover. It should be running whenever the Fridge is calling for cooling. Check to see if this fan is running. My suspicion is that it is not running. Replace this and you should be back in business.
You will see the fan assembly at the bottom right corner of the picture.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174550&diagram_id=28601573#d28601573
My frig is making a buzzing sound
Well if the buzzing is coming from the compressor area then that could very well be the compressor relay. If the buzzing is coming from inside you might very well have ice building up, maybe a defrost problem causing the evap fan to maybe rub some ice. if it gets worse and the fresh food compartment begins to suffer and warm up then maybe a bad heater or defrost thermistat. All these components and a way to check em all can be found in this AMANA BOTTOM MOUNT SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 10, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Vegetables frozen in vegetabe drawer
your refrigerator door (ajar) check coldcontrol
Mar 01, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Have Amana refrig with bottom mounted freezer Model ARB2217CW. Noticed the last day or so it makes a buzzing noise--almost like an electric shaver then it shuts off with a click. Today items in freezer...
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
Aug 27, 2008 | Amana Refrigerators
Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
330 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
