Need the installation data on a 1986 cozy comfort wood stove number70601
    Brigadier General:
  • 4,736 Answers
I hate to be the one to rain on your parade, but the chances of finding the owners/installation manual for a 20+ year old wood stove is next to impossible. In addition, if you live in the U.S., Canada, or the UK, this stove doesn't even come close to meeting the EPA, NFPA and Home Owners Insurance standards. In addition, I would be concerned about the condition of a wood stove that old and and how safe it would be to operate. For your own piece of mind, you should check with your Home Owners Insurance carrier to see if they will cover a loss, that was due to the use of this wood stove.
Posted on Mar 28, 2011
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Is it possible to install a wood stove in a room with carpet floors
Yes, but you need to put down ceramic tile down around the wood stove. Go to your local wood stove dealer and ask for there recommendations. It can be done.
Feb 14, 2011 | Heating & Cooling
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
I have a Comfort Glow ventless gas heater that we only use for emergency heat during the winter. The last time we tried to use it the pilot light lit perfectly and burned perfectly when the knob was...
This sounds like the connection for your thermocouple has lost a good connection.
Try this link to see how to properly clean and seat your thermocouple.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Sep 27, 2010 | Cozy (W352E) Heater
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
Heating & Cooling Logo
526 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
