Question about Refrigerators
My GE PT122MFMARBB Profile, top freezer, refrigerator is leaking water from the top/rear of the refrigerator compartment at the air supply housing bolted there. I suspect it is freezer condensate being redirected by a plugged drain line but I cannot locate that line or a schematic to detail it. Will the line be obvious from under the unit so I could run a wire "up" it in an attempt to clear it? Mike
  • 1314 Answers
SOURCE: locate evaporator condensate drain tube
next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Posted on Jan 26, 2008
  • 51 Answers
SOURCE: Plugged defrost drain line in KitchenAid Refrigerator KTRS22KHBT00
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
algae, bread ties andf other thing mysteriously get in there and clogg it
Posted on Jan 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: how do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Posted on Mar 13, 2009
lojacksdad
  • 121 Answers
SOURCE: I have a Maytag MTB2156DE refrigerator with an ice
the water line comes from the bottom back of the fridge it sound like you have a blocked line meaning
you have a bad water replace valve and clean out line
Posted on Apr 13, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
Ge profile fridge side by side makes only 8 ice cubes per day
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Nov 06, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Water is leaking from under the freezer into the refrigerator section, Is there an easy fix for this.
This is a common problem found with that model. Link below shows you how to solve it. It appears with what you said is the water is coming from the freezer compartment. If so then it can come from 2 things. A frozen defrost/cogged drain or your ice maker is leaking. Let me know how to refine your problem closer. Thanks, Sea Breeze
kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 15, 2009 | GE Profile Arctica Stainless Steel Top...
Our ge profile is leaking water above the icemaker, help
Sounds like the inlet water valve for the icemaker is not shutting off 100%. That would result in either A.) a block of ice plugging the tube where the water passes through from the outside of the freezer into the freezer compartment, or B.) an ice waterfall in the freezer into the ice bin and/or down the back wall of the freezer compartment.
Solution to either: replace water valve and remove ice with the aid of a hair blower.
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
