Question about Goodman CPLE24-1 Air Conditioner
AC is not working and there is a click when turned on. it hums but then stops and fan does not spin
  • Robert Mar 28, 2011
    Check to see if you are getting 240 volts at the contactor coil. Let me know what you find
  • 40 Answers
The problem is the capacitor need to be replaced inside the unit
this is an inexpensive part
Posted on Apr 05, 2011
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
Duo therm quick cool ac
if you can spin blade freely by hand change capacitor.
May 21, 2013 | Dometic Rooftop RV Air Conditioner
Fan stopped working on our Bosch rangehood (Type D-FX41-8 or E-Nr. DKE935AAU). Lights working but the fan only inhibits a humming sound.
hi ;
the fan motor needs repair , the cause of humming is the vibration of induction on AC current in the motor.
if the motor stopped means it has faulty shafting and bushing, or maybe the starting capacitor needs a replacement, don't turn it on or use it to prevent burning of induction wire,
also it needs a qualified technician to repair ,
Sep 03, 2011 | Kitchen Ranges
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
I have a lennox ac unit model M/n hs 29-029-2p S/n 5802g 11144 the fan just stop working and the motor was making a noise like it was humming plus no cold air was coming through our house we purchased it...
The fan stopped working and the compressor overheated due to this. Turn the disconnect (switch by outside unit off) and let cool.
Try spinning the fan by hand. If it moves freely replace the capacitor, if not replace the motor.
Aug 21, 2011 | Heating & Cooling
Hi' I have a coleman roof top AC unit on a 1991 Tioga i just purchused a couple of months ago! When i turn on the AC it makes a humming sound...no fans spin or no air comes out! If i let it hum for...
The blower motor is seized up...you will need to get up top and remove the cover...then remove the fan blades and the motor and replace the motor....sometimes a temp. fix will be to get WD-40 and then oil worked into the bearings...but that is usually a very short lived fix...
Replacing the motor can be frustrating and time consuming, so you may want to hire someone to do it for you...you may also find that a replacement unit is more cost effective..
heatman101
Jun 14, 2011 | Dometic Rooftop RV Air Conditioner
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
Broken AC window unit Kenmore
starting capacitor is bad (THE STARTING CAPACITOR IS A BIG METAL BLOCK MOUNTED ON OR NEAR FAN MOTOR)
Jan 17, 2008 | Heating & Cooling
Heating & Cooling Logo
124 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
