Question about Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor
On the edges of items on screen it looks shimmery or wavy.
    Guru:
  • 433 Answers
Replace the data cable with the original one
best regardes
Posted on Mar 28, 2011
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
Double vision on the left edge slightly
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jul 01, 2012 | Sony KP-51WS500 51" Rear Projection...
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
LOW SOUND OUTPUT ON MY REEL TO REEL, SOMETIMES ON ONE SPEAKER ONLY..
Let me guess - the LEFT channel.
If it's a 4-head deck, the Forward tracks are arranged across the physical tape surface, front-to-back as follows:
BACK
Side 2 Left
Side 1 Right
Side 2 Right
Side 1 Left
FRONT
As you can see, the Left channel is close to the edge of the tape where most tape and head wear occur. High frequencies are affected first.
If you examine the edge of the tape when it is stationary there should be no waviness as this would cause poor head-to-tape contact.
Shine a high-intensity light on the tape where is passes over the heads. You should be able to identify the tracks. Looking closely you might also notice a worn pathway across the heads caused by miles of tape over the years. It changes the contour of the heads and how the tape rides on them. Wear can look like shiny bars (perpendicular to the tape travel) with rounded or wavy edges (not ruler straight).
Or it could just be dirty heads and transport.
Mar 09, 2010 | Audio Players & Recorders
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
Monitor has dark wavy lines on edges
Hi...there,
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
I need replacement screens
the inside screens for this tv is screen assmbly rca part number 258513.. the outside plexi is known as the "supersheild" rca part number 258797
Apr 05, 2008 | RCA D52W19 52" Rear Projection Television
Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor Logo
59 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
