Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Over heating showing oh water to hot - Dream Maker Spas Dream Maker Ez Spa Hot Tub
    Problem Solver:
  • 20 Answers
It sounds like you may have either too slow of water flow moving through the heater ( caused by a dirty filter ), or you may have a bad high limit sensor. Check to see that the filter is clean first.
Posted on Apr 04, 2011
OH code for x500 how to repair?
if water flowing possible bad temp sensor or recirculation pump running too slow
Jun 13, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Whered can I purchase a printed circuit board for 8203 series spa and what is the cost?
OH is the Over-Heat event code. Not likely related to the board, this comes up for a number of reasons -
Flow issues cause the heater tube to get too hot. Dirty filter, suction blockage, low water level etc...
Hi Limit sensor has failed or the temperature sensor reading incorrectly.
Usually its a flow related problem
Aug 05, 2012 | Pool & Spa
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
My hot tub had a OH where the temp usually is, then went blank and i wasnt able to reset it. i just replaced the cord and resiliconed around the temp readout
This is probally your temp sensor. Where it is on your system is hard to say. If you have a book on the system it will be in there.
Jul 04, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
It is no longer brewing really hot coffee. I drained all the water out and now I am wondering how many caraffes of water to put in initally?
Oh no. ... ok don't panic.... put in the same amount of water your coffee Caraffe holds. If the coffee maker is one of the kinds I recall, it holds water and heats it while you pour in another pot, it pushes the hot water out to fill your caraffee pot. Then you will have to add one more pot only.
When the water quits heating it is a heating element that is acting up. Sometimes the fuse finally gives up. The trick is locating and removing fuse, and replace heating element. These require a service tech to do because of soldering, and making sure the electrical parts are put back in place properly.
Apr 21, 2008 | Bunn BT10B Coffee Maker
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
183 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
