Computers & Internet Logo
Posted on Mar 28, 2011
I tried installing 7 zip on my computer but i still cant extract files.
jjashforth
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 28, 2011
jjashforth
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1470
Points
53
Do you have it set to your default handling program for .zip files? It should do it by default, however, sometimes you need to set it manually. right click on the zip file, select "open with", navigate to an option called "other programs" (or something of the sort) and find 7 zip in the list of programs. On the bottom of the box there is a check box that allows you to "set this program as the default handler". You want to check that box.
Winzip 15.5 activation
If you have purchased Winzip and need help, check here...
http://winzip.com/land_support.html
If all you need to do is unzip ".zip" files, you do not need to purchase WinZip. Windows XP, Windows 7, and Windows 8 all have a free extraction tool. You just right-click on a ".zip" file and click "Extract All". First, if you have already downloaded and installed the free WinZip, you can just Uninstall it.
I cant open msi files on my laptop
Hello the file is probably in the zip format (compressed file)
and you need to unzip the file before you can use it.
Here is a free program:
http://www.7-zip.org/
Download and install the exe file.
When installed right click on the zip file and choose 7 zip and extract here or to a folder.
Other files from msi uses adobe reader.
Download here:
http://www.adobe.com/downloads/
Good luck
I have windows 7 64bit installed,and i cant installing my Leadtek Winfast icam100M i have download vista 32 bit driver for this but i dont have image from webcam just sound
Hi
Please download the driver for windows 7, after downloading extract the zip file and go to setup file and install. after installing reboot you computer and try... your problem will solve.
If any problem to downloading check the other's link
http://drivers.brothersoft.com/leadtek-winfast-icam100-m-driver-1.2.53-34523.html
If your problem solve give me the thumb
It don't work...
I believe you were trying to extract a compress file. You could try other software, which is capable of unzipping or extracting compress file.
here are the options:
1. winrar click the download link here http://download.cnet.com/WinRAR/3000-2250_4-10745708.html
2. 7 zip click the download link here http://www.7-zip.org/
Ryan
1helpful
I have downloaded Drivers for Olympus VN-4100PC but cant install them as they are a zipped file
On any computer running Windows XP or Vista or 7,
right-mouse click on the ZIP file, and choose "Extract All" to start the "unzipping-wizard".
Once unzipped, look for a "setup.exe" file in the newly-created folder. Double-click to run that program.
11helpful
2answers
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
2helpful
I have just changed my laptop with windows 7 but i think i need a driver to update my olympus vn-4100pc is there one
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
I don't think it's a zipping problem
Create a folder and put the zipped file in thre and extract to same folder. Then turn off computer, install the peripheral, and reboot. When computer detects presence of new hardware it will ask for driver. Then direct the computer to the folder where you have all of the extracted files and the OS will find the necessary driver and take care of business for you.
Grand Canyon Tech
Grand Canyon Tech
