I want to replace the lamp in my JVC HD52Z575 television, where do I locate the lamp?
    Brigadier General:
  • 8,909 Answers
JVC TV mod HD52z575 SE#07080014. After I turn tv on within seconds The "menu" dark-box appears on the screen how can I take it off
If it's just a black box nothing in it,it sounds like you have tha closed caption decoder on check you instruction book for directions how to turn it on/off it's probably set on a text mode.
Jan 31, 2015 | JVC Televison & Video
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
Dark screen - need picture calibration settings.
That\'s my best guess.
May 21, 2013 | Televison & Video
Jvc model #HD52Z575 Has a red screen
Check your LVDS connector. Make sure it is tight on both ends. If it is not, tighten it. If it is resolder all the pins.
Jun 21, 2012 | Televison & Video
JVC HD52Z575 hdtv - replace lamp but screen still dim
A ballast is possible but was the Lamp you replaced JVC or a generic lamp from the internet?
Mar 12, 2012 | Televison & Video
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
The sound suddenly went out on our JVC HD52Z575, that is about seven years old and otherwise works well.
The sound board is gone.... it's not worth it to repair. Just use the analog audio out from the TV to the external audio system. that's what I do on mine.
Dec 27, 2010 | JVC HD-52Z575 52" Rear Projection...
Jvc hd52z575. Just replaced bulb and can't get the audio to work through Tv Help please!
first check to make sure the red and white cables are plugged in, then go into the menue , under audio hilight the tv speakers, make sure they are on, if they are, make sure the mute button wasnt turned on
Jan 08, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
