Question about Lexmark Optra S 2450 Laser Printer
I have a Lexmark Z2400 printer and i needed to use it to print some papers. I plugged in the USB into the computer and it said that it had sucessfully installed on my computer but when i tried to print something, nothing would even printer. i need help.
    Problem Solver:
  • 17 Answers
What computer operating system are you using? If the manual claims compatibilty, it may just require a reboot. You may also wish to go online and download the latest drivers. Even the disc that accompanies the printers are often out-of-date. Here's the link:
http://support.lexmark.com/index?page=productSelection&userlocale=EN_US&locale=EN
Posted on Mar 28, 2011
The compuer is not connected
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Printer operates unexpectedly but soesn't draw through paper or print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website. Select your operating system, download and execute the file.
Dec 08, 2011 | Lexmark Office Equipment & Supplies
I installed Windows 7 and now I have no connection to the computer. The printer is connected to the router but won't communicate with the HP G60t-200.
Try to remove the existing printer driver from your computer. Go to Start > Programs > Lexmark Z2400 Series > Tools > Uninstall. Your computer will then uninstall the Lexmark program. After the uninstall process, reboot pc when prompted.
When your pc turns on, check if your operating system is running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to re-install the Lexmark Z2400 Series printer driver: - Lexmark Z2400 Series driver for Windows 7 32-bit - Lexmark Z2400 Series driver for Windows 7 64-bit
Download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps.
Oct 26, 2011 | Lexmark Z2420 Printer
My printer will not print from the documents program
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark X5495 All-in-One &USB...
Print mode does not work pages come out blank
It could be the cartridges in the printer. Disconnect the printer from your computer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Reconnect the printer into your computer. Try to print again.
If that doesn't help, try to clean the cartridge nozzles using the Lexmark software on your computer.
  1. Click Start > Programs or All Programs > Lexmark Z2400 Series
  2. Click Maintenance > Clean Cartridges.
  3. Click Print.
  4. Follow the instructions on the computer screen.
  5. If print quality has not improved, then wipe the cartridge nozzles using a slightly moistened soft cloth to clean it from possible dirt and clogs.
You can also reinstall the printer driver on your computer to repair any corrupted files necessary for printer communication and processes.
Jun 22, 2011 | Lexmark Z2490 Multifunctional InkJet...
Connecting it to wireless
This article in the Lexmark website should guide you on how to setup your Lexmark Z2420 printer for wireless printing: How to Set Up the Lexmark Z2400 Series for Wireless Printing in Infrastructure Mode.
Apr 17, 2011 | Lexmark Z2420 Printer
1. The printer is printing everything in landscape. I have checked the settings and it is set to portrait printing. I tried changing it to landscape and then back and it still printed in landscape. ...
1. You could try to reinstall the Z2420 driver on your computer. 2. Try to reset the wireless network adapter of your printer. Follow the instructions in this article from the Lexmark website on How to Reset the Internal Network Adapter on Lexmark Z2400 Series Printers. Open Lexmark Wireless Setup Utility to reconfigure your printer to connect to your wireless network.
Thanks.
Feb 24, 2011 | Lexmark Z2420 Printer
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
My Lexmark Z2420 is not working at all.
From the manufacturer's web-site:
enter 'X4650' or 'Z2400', and do a search.
Select the correct device-driver for your printer and your Operating System.
Download it, and install it.
Jun 01, 2010 | Lexmark X4650 InkJet Printer
Lexmark Optra S 2450 Laser Printer Logo
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
