Question about Planar (93p3304) Motherboard
IBM Thinkpad T40, Windows XP Prof Computer works fine for 20 - 30 minutes, then screen goes blank. Backlight still funtioning at this point, computer unresponsive to any keystrokes, ie. Alt+F4 for shutdown. Unit can only be turned off by pressing and holding the power on button. Fan runs normally, CPU replaced with known good CPU, CPU/fan cleaned w/ alcohol and new heat sink grease appilied. Screen becomes sporatically grainy and picture shifts with random black lines flashing 1 to 2 minutes before screen goes blank. Thanks, JB
    Guru:
  • 433 Answers
Try another vedio card (vga)
best regardes
don't forget to vote if you see that helpful
Posted on Mar 28, 2011
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
I have an IBM thinkpad T40 when I turned on the laptop the image doesn't appear and that times it would but then after a few seconds or minute the screen blanks out and won't appear again and sometimes...
There is no problem in your motherboard. In your motherboard, clean your ram and also where ram is put. Then restart your system again it will work. When it will not work please change your ram. Then it will work.
Nov 07, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
Boot problem
check it on bios whether the hard drive is detecting or not, if detecting then recover OS using recovery Cd
Nov 15, 2008 | IBM ThinkPad T40 2379 Notebook
Ibm t40
Yap actually i greet you first
what your system is prompting you is that your Processor is getting Bad and you will need to replace it with a new ones ok
After that your system come back to life .
thanks
Rate this solution
Oct 20, 2008 | IBM ThinkPad T40 2373 Notebook
T30 boots but stop , in windows inst.
I have a ibm 2373 that will only start up and show the ibm and windows xp logo briefly,then the screen goes blank,but i can hear the fan running.
Oct 01, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad t40
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
http://support.microsoft.com/kb/174630
THe most popular windows issue in all the land.
Oct 24, 2007 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
91 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
