Question about American DJ VMS4 Digital DJ Work Station
The Crossfader does not work. I just bought it. I don't think it's broken even though everything else works.
    New Friend:
    Problem Solver:
  • 4 Answers
Exactly the same thing happened to me think they send them out like it so you get the info fader upgrade I took out the two screws popped the fader out it was cruded up so I sprayed contact cleaner in to it.Just to clarify you have it set up right if your using it just with software you need the in on chan 2 out on chan 3 on the front and make sure the curve is set right
Posted on Jan 04, 2013
Guitar tuning peg seems like it might be broken it will tighten the string to a certain point then it clicks and its completely loose again...I'm new to guitar so I don't know If this is normal
It seems like you wound and tightened your string on the tuning peg loosley. Try wounding the string at least 4-5 times around the peg after you pass the wire though it and then after winding pass it through the hole again. Tighten well.
If that doesn't work your peg might be broken, but looking at it on the video seems that it's not, even though you can't see it clearly.
Try tightening the screws on the peg, since there's a lot of tension on the highest string and it might cause the peg to click back because the tension is too high and it's loose.
Jan 30, 2013 | Music
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
HOw do you use the crossfader if all your music is coming through one port???
The crossfader is to gently fade from one source to another. If you only have one, the crosfader isn't useful... it would act like a plain fader with one side being dead and the other at full volume.
Aug 06, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hello, My Boss CS-3 Compression Sustainer pedal is having issues. I bought it around 6 months ago. When I first discovered the problem, it didn't work at all when turned on. It just made this feedback...
Make sure you use Alkaline battery and NOT rechargeable type... the rechargeable battery will NOT work in the pedals (their voltage is lower even though they are labeled as 9 volt replacement).
Other internal problems can be due to cracked circuit board or broken solder joints. These are very common as people step on the cables when plugged in. This breaks the connection inside. A fuzzy sound often occurs when one of the contacts is marginal due to bad solder at the jack terminals.
Mar 22, 2011 | Roland Boss CS-3 Compression Sustainer...
My vmx1000 mixer the crossfader only cuts out one side the other just contiues to play no matter what side u put it on
I suspect that one element of the crossfader pot (slider) is broken. Possible cause is if something fell on the knob or wear from use.
If one end breaks on one channel, the opposite end side will remain on full while the other channel will behave normally.
Replacement of the dual pot will LIKELY involve removing all panel knobs to remove the circuit board to replace the pot after disassembly of the unit. Not for the casual DIY person.
Nov 17, 2010 | Behringer Pro Mixer VMX1000USB...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
American DJ VMS4 Digital DJ Work Station Logo
189 people viewed this question
Top American DJ Music Experts
Michial Gueffroy
Marvin
Marvin
Are you an American DJ Music Expert? Answer questions, earn points and help others
