Question about Canon Office Equipment & Supplies
I have a system error code E100. - Canon Office Equipment & Supplies
  • jduncan595 Mar 28, 2011
    I have a canon laser class 730i printer. It shows system error E100. How can I fix it by myself?
    Thanks for the help.
    My machine is not old enough to have the drum replacement. I opened the front cover and reset the cartridge. Then it shows the Incorrect paper size error. I reset the paper size and the alarm went off. The problem is solved.
    Thanks again.
    Genius:
  • 1,570 Answers
Hi
Faulty scanner unit/laser unit, Just replace this unit and it will back to normal. But first try to remove and return firmly the drum unit and maybe it might help solve the problem.Regards
Posted on Mar 28, 2011
  • 624 Answers
Hello and Welcome to FixYa! Sir,
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
I hope you will have a clear picture now, I'll suggest not to Do it yourself, this may get more messy. Laser unit is a precise thing.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
4 Suggested Answers
  • 66 Answers
SOURCE: E100 error
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Posted on Dec 19, 2008
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
SOURCE: canon-lbp2900-error-code-e100-0000.
J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
Posted on Apr 12, 2011
Sir, My machine is Canon GP405, its showing me error code E100-0002 while i making copy, after paper pickup its throwing this error code. Please help me.
This *may* be of help.
E100 e100 0001 e100 0002
Before doing anything else, try unplugging the machine, leave it unplugged for a half hour (overnight?) and see if it works OK afterwords.
Dec 26, 2017 | Canon Office Equipment & Supplies
What should i do with error e100-0001 on mf4410. i changed fuser film and when i closed the all the panels the machine falshed this error code e100-0001.
Nov 13, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
SYSTEM ERROR E100 on canon IR1018
Main cause The laser driver/BD PCB is faulty (laser activation failure, BD
detection fault). The DC controller PCB is faulty. The image
processor PCB is faultly.
or drum is faulty.
Oct 20, 2012 | Canon IR1018J Black and White Copier
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Mar 26, 2009 | Canon Office Equipment & Supplies
Error E100
Dec 31, 2008 | Canon PC-1060 Black and White Copier
E100 error
Hi Paikin,
Rgs
S88
Dec 18, 2008 | Canon LaserCLASS Fax 710 Printer
Systems Error E100
ERROR E100 is results when DRUM UNIT is not sitted properly , please check it is engaged with toner ( developing assy).
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
I have an error code on my printer Error Code: E100 0000 E100 0001 it is a canon LBP5000
Well im having the same issue E100 error on my xbox one as it was never update till the other day i was thinking is it possible if the nand dumpable and get the keys or signature from it and replace it with a working nand i know it still works cos i able to do the recovery mode with the offline update dianogtic from microsoft but still error E100 after reset
For more help visit cbr tech solutions
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
70 people viewed this question
old marine
old marine
