Question about Sanyo PLC SU07N LCD Projector
I hv Sanyo PLC-SU07N Projector - the image is blue
    Problem Solver:
  • 9 Answers
I have a possible solution however it may not be THE solution your after, you'll probably be able to tell very quickly if it isn't, this will only apply if you are using either a component video signal or a PC/laptop signal to send to the projector.
If you are using a laptop or desktop to hook up your projector, I would try first of all double checking that it's correctly plugged in, and if you still have no luck try a different cable.
It's likely to be the cable because when the signal goes down the cable it's split into 5 different signals. 3 of these are the colour information for Red, Green and Blue. Depending on what you mean by 'image is blue', it could mean that your either not getting the information for Red, or your not getting the information for Red AND Green. If you want to test this, open up microsoft paint while connected to the projector and create 3 boxes, then fill 1 completely red, 1 completely green and one completely blue. If you are missing the information to any of these colours then that colour will appear black on the projector screen.
In component video the signal is split down 3 cables (rather than 5) and 2 are colours (rather than 3)... Red and Blue. Check that the cable running red (Usually labelled Pr on the DVD and projector) is completely plugged in (some of these are really tight, but it's important that it goes all the way) and also that you have plugged into the correct slot, for instance that you have plugged into Pr and not the right Audio channel, both of which are coloured red.
If you are still not having any luck then I would suggest using a computer monitor or a television (depending on what type of signal your sending it) to test the projector. Plug it in instead of the projector and if it works then the issue lies with the projector and I have at least narrowed it down for you.
Hope this has been helpful.
Posted on Mar 29, 2011
I had my sanyo plc xu70 suspended from ceiling.. how do i rotate the image?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "Option" .
3,select "ceiling"
4,select "Yes"
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mar 26, 2012 | Sanyo Projector Lamp for PLC-XU70
I hv sanyo plcxu48 , its power on led continously blinks in red ,projector not getting on at all, pls advise
if you count the number of blinks and time between them and repost I will try and sort out the problem, the blinking is normally indicative of a fault
Dec 17, 2009 | Sanyo PLC-WXU30 Projector
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
Jul 17, 2009 | Sanyo PLC XU35 Multimedia Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC XE31
Sorry if this is a bit late...
Hold down the MENU and IMAGE buttons on the remote for more than 10 seconds and the remote toggles to the other projector.
Banni
Nov 04, 2008 | Sanyo FOR PLC-XE31
Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Open Questions:
See all Sanyo PLC SU07N LCD Projector Questions
Sanyo PLC SU07N LCD Projector Logo
167 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
