Question about Car Audio & Video
I NEED A FRONT PLATE (OR SCREEN) FOR MY AVIC-920BT. IS IT AVAILABLE AS A SEPERATE PART, IF SO HOW MUCH AND HOW LONG TO GET IT.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try looking at pacparts.com.
Posted on Mar 28, 2011
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
I have installed an AVIC-X-920BT into a 2000 Toyota 4-Runner. Once installed, not all of the ICONS are available - example address entry on GPS (however, POI icons, etc. are lit). Any thoughts?
I think you have it hooked up correctly, but I would say that if some icons are missing, the signal may not be getting to the unit for the respective icons.
Jan 02, 2011 | Pioneer Avic-x920bt GPS Receiver
How do i install a clutch on a 1990 laser?
You need to get a manual. Try the Haynes manual for your car. Try autozone; generally available for around $20. This is not the type of thing that can be covered here in enought detail to do you any good.
Basics are;
disconect the negative battery cable, set parking brake
locate the trans mounting bolts
get something to support the engine and something to support the trans
seperate the trans from the motor by removing the bolts. On transverse mounted engines you will probably have to pull the trans to get enough room to remove the clutch and you'll probably have to remove the 1/2 shaft axles (front wheel cars) or drive shaft (rear wheel drive cars)
If replacing the entire clutc assembly (pressure plate, flywheel, and clutch), loosen the pressure plate mounting bolts gradually working your way around the pressure plate. If only replacing the clutch then seperate the sperate the pressure plate from the flywheel and remobe. Align clutch with a clutch allignment tools and replace pressure plate. Torque bolts to spec. reconnect the trans to the motor. Few other things to think about. You should replace the throwout bearng when doing a clutch. Lube the clutch fork as directed without getting lub on the clutch face. Hopefully I have convinced yu to get a manual or you will be hating life if you take this on without it.
Feb 21, 2010 | 1990 Plymouth Laser
Lg viewty ku990 Broken Screen!!!!!
The top screen is the touchscreen,underneath is the LCD screen,both have seperate ribbon connectors and are seperate components although they may be glued together.
Sep 18, 2009 | LG KU990 Viewty
Pioneer AVIC-N3. What wires power it on??
the pioneer avic n3 has a seperate brain system and there is a cable that hooks the two together its called like the 13 pin wire or something and once you hook the brain and the head unit together it will have the display and everything else
May 25, 2009 | Pioneer AVIC-N2 Car DVD Player
Display not working
just got a tech bulletin from pioneer in my bulk mail(almost trashed it). they said its a recall on all avicn1 and 2's. the ribbon wire going from unit to screen fails after many cycles. they are issuing free repair.
Notice: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 To: January 3, 2007 Dear Valued Customer: Re: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 We would like to inform you of a potential service issue with Pioneer's AVIC-N1 and AVIC-N2, inform you of our plans to resolve this service issue, and ask for your help in notifying consumers. If a consumer is not experiencing any issues currently, there is no need for the consumer to take immediate action because the one-time fix to resolve the service issue will be available if an AVIC-N1 and AVIC-N2 later experiences the service issue. _Importantly, the service issue does not pose any health or safety risk._ Pioneer is aware of a potential issue with the flex-cable powering the flip screen to the AVIC-N1 and the AVIC-N2. After a number of power cycles, the cable has been observed to fail and cause the unit to malfunction (symptoms may include, but are not limited to, the flip-screen becoming blank) -- flex-cable failure can only be confirmed by Pioneer; standard service charges may apply for service issues not related to the flex-cable upgrade. This issue may affect almost all AVIC-N1 units and AVIC-N2 units. Please contact Pioneer at the number listed below if you have a question about whether your AVIC-N1 or AVIC-N2 unit is affected by this issue, or if a specific malfunction affecting your AVCI-N1 or AVIC-N2 is related to this issue. To address this issue, Pioneer is providing a one-time cable upgrade to consumers for their AVIC-N1 and AVIC-N2 at no charge to consumers for parts and labor. Pioneer will offer the free upgrade either upon request or automatically if an affected unit is serviced for another reason. Pioneer will exclusively perform the free cable upgrade for all units (i.e., no other service facility should perform the cable upgrade). If you own an AVIC-N1 or AVIC-N2 and you are experiencing the service issue, please contact Pioneer Customer Service toll free at 800-421-1603 to arrange for the cable upgrade. Pioneer service representatives are available Monday through Friday, 9:00 a.m. to 7:30 p.m. (Eastern Time). Customers who have paid for the cable upgrade are eligible for reimbursement of certain service costs if sufficient proof of service can be provided -- please contact Pioneer at the above-listed phone number for more information regarding reimbursement rules. Customers can also review FAQs regarding this service issue. Click here to view the FAQs. We sincerely apologize for any inconvenience this service issue may cause you, and we thank you for your cooperation and continued support of Pioneer. Sincerely, Pioneer Electronics (USA) Inc. *Pioneer Electronics (USA) Inc., 2265 East 220th Street, Long Beach, CA 90810* ------------------------------------------------------------------------
___________________________________________
owner of
Motion Marine & Car Audio
the florida keys
Dec 08, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
AVIC-N1 opens to blanks screen and none of buttons work
It is probably the ribbon cable that you can see when the screen closes. This is a known problem and the part is sometimes hard to find. But is available.
Mar 26, 2008 | Pioneer AVIC-N1 Car DVD Player
A big blank nothin
Hi sounds like its the cable. the part you need is gxx1257.
you can get this from www.carradiocode.co.uk
Regards
Mark
www.blueice-electronics.co.uk
Nov 27, 2006 | Pioneer AVIC-N3 GPS Receiver
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
