Question about Copystar CS-1620 Copier
It says that the toner is low. I dont know how to access the toner to see which one is low. I cannot find my instruction manual. Copystar CS1620 This only a black ink copy machine. So I am guessing its just the black. I dont know how to get to it to change it. Thank you
  • 325 Answers
Http://usa.copystar.com/americas/jsp/Kyocera/resource_details.jsp?pid=11917&rid=12081
The above link is model specific for your copier
http://usa.copystar.com/americas/jsp/upload/resource/12081/0/1620-2020ENOG1B.pdf
The above link is the user manual (.PDF) for the copier. Toner drawers are located on the front of the copier with a fold-down style of hinge. You hinge the door downward, pull out the old toner and replace with the new.
Thank you!
Posted on Mar 28, 2011
  • Andrew P.
    Andrew P. Mar 28, 2011
    Page 2-2, of the .PDF,is the exact location identifier for your toner location!
    Thank you!
I have a copystar cs-6030 that the toner motor will not turn off.
Usually when it out of toner the toner keeps running , just put a new toner then after 2 minutes the toner motor will automatically stop, READY will appear.
May 18, 2018 | Copystar Office Equipment & Supplies
Copystar 1500 flashing C-7 and 980; have emptied waste toner container, but codes still flashing. need maintenance number to reset?
If you still need this answer, say so. I have a tech who can answer this. Tossing the mahcine is also advisable.
Aug 13, 2014 | Copystar Office Equipment & Supplies
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
Copystar gs1810 replaced th toner but I can't get
The toner auger is probably clogged up. You will have to disassemble the whole dev unit to clean it out.
Jun 01, 2010 | Copystar CS-1810 Copier
I just replaced the toner. Toner light on
Keep opening and closing the front door until the toner catches up. Did it have a plastic seal that you forgot to pull off?
Nov 25, 2009 | Copystar CS-1810 Copier
New toner installed, toner still registered as low
Throw in nearest skip and buy a Kyocera printer!!
Jul 07, 2009 | Copystar CS-1510 Copier
Hello there! This is the first time that our printer needs to have the toner cartridge changed, we dont know where to locate the old toner area
If you open the fron door you can't miss it"s a big box there is a lever you may need to release so you can slide the toner bottle out
hope that help
Dec 02, 2008 | Copystar CS-2030 Copier
Copystar CS-1500 Copier Problem
Did you remove the drum unit when fitting the toner? Try reseating it.
Nov 25, 2008 | Copystar CS-1500 Copier
Gestetner 2302z photocopier toner light stays on but has toner in it
The error code has got something to do with your fuser. Either the lamp is blown, the thermistor could just be dirty or the fuse has blown. These manuals are very old, do not know if it will be easy to get the manual.
Mar 11, 2008 | Office Equipment & Supplies
Copystar Royal - NC4A NETWORK BOARD 10BASE T/2 Print Server?
Here you go the official service site for copystar and kypocera, contact them and they will help you, if not , look for any copystar dealer can help you.
www.kmaconnect.com
let me know wat happen, if you didnot find any solution let me know where is ur location so i can hook you to some dealer.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jan 19, 2008 | Copystar Royal - NC4A NETWORK BOARD 10BASE...
Copystar CS-1620 Copier Logo
175 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
