Question about Motorola Mobility RAZR V3i Cellular Phone
I need to connect a bluetooth to my razr - Motorola Mobility RAZR V3i Cellular Phone
  • 66 Answers
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Posted on Mar 28, 2011
Bluetooth wont connect to any devices on my razr k1
make sure that you are following the right process. It should be compatible. when you set your phone to "find me" the bluetooth symbol should come on? It should be flashing. Was the headset linked to another phone before? If so you may need to "reset" it. make sure that you have turned the headset in the mode to link up with a device then use the razr to find a bluetooth device. it Should hook right up. Also make sure bluetooth is turned on on the razr
Jan 03, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
My Razr phone 'unable to connect' to blackberry 8310 bluetooth
you have to hold down the power icon till it flashes red and blue then its ready to connect, then select your search settings from your razr. it should find it and ask you for a code. its usually 0000
Apr 15, 2009 | Motorola Mobility RAZR V3
Transfer pics frm moto razr v3 to laptop using bluetooth
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
Jan 04, 2009 | Motorola Mobility RAZR V3
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth Connection to Mazda Handsfree Is No Longer Handsfree
hi,
bluetooth connect is only going to work for up to 30ft in distance so if you go to far from the car it will disconnect because it lost the bluetooth signal.
please rate me. thank you.
May 20, 2008 | Motorola Mobility RAZR V3
Will not auto connect to Prius bluetooth
It may be the setting for the bluetooth device on your V3.
Go into bluetooth,
Click on device history,
Go to your device and click edit and check the settings in there.
I don't know if you have already checked this but I hope it helps anyway.
Mowcius
May 15, 2008 | Motorola Mobility RAZR V3
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Motorola Mobility RAZR V3i Cellular Phone Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
