Question about Craig CLC501 15 in. TV
Commercials are perfect, but the actual shows the eople are pink/red. Black actors are so black they disappear into the background. All the actors hair look black/dark gray and matted. The PC options will not light -up to give me the best picture.
  • wilsonty Mar 29, 2011
    This is basically a new sFlat screen TV. i've had this TV less than 90 days. I have had these problems from day one.
    tyronew61
    Can you give more information about what video adjustments I need to make?
    Tyronew61
  • 325 Answers
This is a mainboard issue (aka tuner board) you will need to replace it. You may also need to check your power supply to make sure the mainboard is getting the proper voltage. The mainboard is lower/center on the tv and the power supply is usually dead center. The powersupply has the main plug-in going into it. Be careful of high voltage dangers! Please comment if there is anything else you need to know.
Posted on Mar 28, 2011
  • Andrew P.
    Andrew P. Mar 29, 2011
    You may try video adjustments, or the panel is defective. You may need to demand a new unit from the place of purchase. These are not normal problems with a brand new lcd television!
  • Andrew P.
    to be honest, it is your preference. I enjoy a high contrast, mid brightness, and mid sharpness video. Everyone has their own likes as far as a picture goes. You should start by resetting to default and adjusting the values of what you have.
    What options are given for adjustment?
Lumix DMCTZ2 Problems
DFid you try to shoot a picture, even not seeing what you are shooting? Try it. Then ale check what happens if you press the display button, (left one under the Menu / set buttons)
Let me know how you and your camera are doing now.
Jul 07, 2014 | Cameras
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
PDF not showing any white text on black background
You need as much memory available to you as possible.
Add some more RAM to the computer.
Increase the swap space size.
Close down all other applications and background processes. Close down internet access especially and make sure that Internet Explorer is not running.
Nov 08, 2009 | Microsoft Publisher
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Pink scrable in background
your cable provider is using high compression causing the distortion.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Screen goes pink
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 27, 2008 | Acer Aspire 5102WLMi Notebook
Westinghouse 32in HDTV-Ready
I called westinghouse with a similar problem(my picture shows up but all the white turns blue or somtimes pink).
they say the problem is similar to that of the xbox 360's red ring of death problem. Now what needs to be done is the unit needs to be unplugged completely for about 30 minutes. this allows the unit to completely cool down. and when the unit restarts and heats up the troubled connections will reflow and all will be fixed.
I tried this and it worked well for my TV. but it is only a temp fix and will need to be done again if the problem occurs.
Oct 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Craig CLC501 15 in. TV Logo
61 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
