I have an isignia flat panel tv that when i try to turn on the tv the light shows that its on but its a black screen. how can i fix this issue? i appreciate your help in this matter
  • 11,361 Answers
You need electronics repair experience and proper tools.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 28, 2011
Samsung flat panel TV. I have sound with a black screen. Can you help me
Hi Cherie, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS.. Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 01, 2016 | Samsung Televison & Video
Power wontcome on
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX ... 1. soft reset - is just turning tv off & back on 2. hard reset - unplug power to tv for 1 minute then connect power to your Flat-Screen
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding ... I get a center led light when its plugged in showing power. ... I have a dynex 42 in and it dose not have stand by but turning on on the light but nothing happens ....Repairing Flat Screen TV - Blacked out with blinking red light ...
i have a 32" rca rlded3258a tv. The red light in the bottom ...
Dec 09, 2015 | Televison & Video
I turned tv on and a black screen came on Why is that or what caused it?
Hi Lisa,
It appears to be back light failure. Please consult a local TV Tech to fix it.
Aug 23, 2015 | Proscan 42LA45H 42 in. LCD TV
Coby 40 LCD TV has splash screen and sound, but no picture
Looks like you might have issues with your screen it self the lights and all internal issues. You might have to take into a repair shop to get it done, a fuse might have been blown up. If you have warranty try to take it in and get it fixed.
Nov 05, 2013 | Coby 40 TFTV4028 LCD TV
L32W861 Black Screen.
Buy THIS main board, and replace it. Most of the time, this should fix your no picture, no sound issue.
Jan 31, 2013 | AOC L32W861 32 in. LCD TV
I have sound but no picture.. had this problem before a yr ago cost me $350. to fix it forgot what they said was wrong but i like the tv so would like to fix it myself or??
same problem with mine its not something you can fix yourself you must sent it back im sorry. since isignia is a best buy only product the fix should be still under warrenty (worked at best buy we warrent the fix for a year if the same problem results we fix it again for free)
Mar 16, 2011 | Insignia 42" LCD Flat-Panel HDTV
LG 50PG20 Plasma,, nothing shows on screen its all black
This model was known for issues with the Y-sustain, Y-drives, and the Z-sustain boards. These boards help process the picture image to the screen.
When one or more of these boards fail, the screen stays black, and you only have audio & on/off.
You could call LG and try to get your TV repaired at a discount if you can convince LG to honor this known issue.
Another issue could be the actual panel has gone bad. The plasma panel in your TV has a two warranty and LG would fix that for free. Well…it would be free as long as it’s not past two years of your date of purchase.
What zip code are you in?
Jun 18, 2010 | LG 50PG20 50 in. Plasma HDTV
Tv turning on and off.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 31, 2010 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
