Question about Vivitar 283 Flash
Arnot@peoplepc.comthe zoom is not working,the flash is on TTL and works,I can't go to man. setting
  • 747 Answers
You haven't supplied enough information as to first what camera are you using this flash on?
A few scenarios.
First the Vivitar 283 is an older flash meant for film cameras there is no way it's going to TTL. It has a manual exposure colour setting in purple, blue,red and yellow which is matched to your camera F/stop from F1.4 through F22 and you manually set the sensor at the front of the flash to the coinciding colour on the sensor (side).
If you have set your camera to TTL then that's all you have done the Vivitar 283 does not communicate with the camera other then to receive the contact to flash.
Another thing if you have that Vivitar 283 mounted to a digital camera then you have most likely burnt out the flash circuitry in the camera due to the extreme high trigger voltage of the Vivitar 283. Digital cameras can use voltages in the 6 volt area while the Vivitar kicks back 300 volts.
You don't have to understand how a few 1.5 batteries can produce this kind of voltage just be fully aware that this is what the Vivitar 283 puts out.
A Vivitar 283 and Digital Camera are a disaster waiting to happen.
Posted on Mar 28, 2011
How do i turn off m zoom nikon sb 800 and switch back to ttl mode.
Go to menu on camera, then flash/bracketing, then set TTL (through the lens)
then set flash the same
Sep 07, 2012 | Nikon Speedlight SB-800 TTL Flash
SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
May 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
Won't power zoom on camera
Robert,
Is flash set on manual or auto zoom? Zoom lens is made for your camera? Can you set the zoom manually?
atdlee@netzero.com
Feb 09, 2010 | Quantaray QDC-900WA TTL Flash
Everything seems to be working with my Canon580EX but it just won't fire.
Jackie,
Try shorting out center pin to outside lead, this will fire the flash. If not, flashtube or trigger maybe bad.
atdlee@netzero.com
Feb 08, 2010 | Canon SPEEDLITE 580EX TTL Flash
Flash zoom function not working
have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Feb 02, 2010 | Nikon Speedlight SB-800 TTL Flash
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
Vivitar 283 Flash Logo
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
