Question about HP Computers & Internet
Is my 2400 all in one printer compatible with using a time warner digital phone service? I can not use my fax part of the printer
  • HP Master
  • 1,879 Answers
Greetings,
No guarantee if a fax that is manufactured for regular analog phone line will work with a digital phone line (VoIP) like yours. Better ask your provider for more information such as a fax that is compatible with their digital line.
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Posted on Aug 05, 2008
    Guru:
  • 1,894 Answers
When any kind of such problem comes first try a hard reset sir.
its done by leaving the unit plugged off from wall power for one night and try using the fax again
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Is there a bios update compatable with dell dimension 2400 that will allow me to change cpu speed/ fsb speed ect.
Windows XP Professional 2005 service pack 2 can improve the speed of your computer.
qasimmi@yahoo.com
Feb 28, 2010 | Dell Dimension 2400 PC Desktop
Which phone can i hook up with printer
If you are referring to a multi-function printer/scanner/fax machine, you can use just about any phone that will work in a typical home. Most office phones DO NOT work with these multi-function devices as they use a digital signal from the PBX in the office.
A Standard phone as well as a standard phone line are required to use the fax capabilities of these units.
(more advanced users will know that you can use a standard POTS line emulator on a PBX - but it requires advanced PBX knowledge, the proper card and phone etc...)
Jan 21, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
I have a dell dimension 2400 & figure out what sata chipset it is compatible with...im trying to learn how to burn games for xbox 360 but not real computer savvy
On the back of your dell is a service tag. Copy it down and go to ww.dell.com and Support and drivers, input your service tag and it will give you the original configuration of hardware and software installed on your computer.
Jul 30, 2009 | Dell Dimension 2400 PC Desktop
Cannot print maps or directions from Mapquest or Yahoo or certificates from on-line surveys. All used to print. Recent change is is adding Adobe 9.1. Advice, please? Thanks!
First start by trying to print from the file menu. A new window will open showing you a choice of printers, select your printer and select ok.
If it prints then possibly Adobe changed your default printer settings.
Again open the printer and faxes folder.
If there is more than 1 printer showing, Select the printer you want to use as the default and select ok.
Hope this helps, Have a great day
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
Unable to access any website form my dell home pc with hi speed
Open internet exploder.
Click on file, and uncheck "work offline"
Now try to go to www.google.com
Mar 02, 2009 | Dell Dimension 2400 PC Desktop
I can;t received faxes on my computer
Are you using DSL connection or Dial-up?
What OS are you using?
The fax line and voice line are using the same frequency so you should be able to fax directly from your pc fax modem when using Dial up connection but in DSL the data and voice are using different frequency. So in normal situations you wont be able to fax using DSL modem unless you use a separate fax machine.
However, if specified during the set-up of the DSL line, the signal can be separated so that some of the bandwidth is used to transmit an analog signal (for voice and fax) while the remaining bandwidth is used to transmit digital data. This allows for the use of the telephone or fax, and computer on the same line and at the same time. When inquiring about DSL with the service provider, specify the desire to use the phone line for voice or fax calls while connected through the computer to the Internet.
Reference the following setup options for using a DSL line with HP all-in-one or fax products.
Please refer to my solutions to your issue at http://www.fixya.com/support/t1440518-want_able_fax_from_computer_even_though
PLEASE RATE MY SOLUTION.
Jan 17, 2009 | Computers & Internet
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
