Question about Thermos Nissan Compact Beverage Bottle FBB500 Grinder
How to remove and replace the belt - Thermos Nissan Compact Beverage Bottle FBB500 Grinder
  • 77 Answers
Your Thermos has a grinder on it requiring a belt? WTF!
Posted on Mar 28, 2011
2005 xl7. How can I adjust alternator?
remove battery neg lug first. do not yank off alternator wires! until
this step is done first, or boom fire or eat acid.
which engine, we cant guess them here.
my guess H27 v6, wrong the 3.6L
all belts covered on car. (accessory)
here is a real 2007 page
seem you get lost at step 7
right>?
26044119-eqsv1nhxqdz21u4tq0h4adgz-1-0.jpg the alternator is NOT adjustable
so why ask this?
the $4 FSM covers this.
under drive belt replacement.
Drive Belt Replacement
Removal Procedure
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Install the engine support fixture. Refer to Engine Support Fixture .
Remove the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Lower the vehicle.
Rotate the drive belt tensioner clockwise to release the drive belt tension.
Slide the drive belt off of the belt idler pulley (1).
Slowly release the drive belt tensioner.
Remove the drive belt from the accessory drive pulleys.
if the post was to remove alternator? is it
do above
then unbolt alt.
end guessing what you are doing....
Jan 08, 2016 | Suzuki Cars & Trucks
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
How to remove belts from 1994 dodge caravan 2.5 liter
Drive Belts
Print
INSPECTION
See Figures 1, 2, 3, 4 and 5
Check the condition and tension of all drive belts every 12,000 miles, or at least once a year. Loose drive belts can lead to poor engine cooling and diminished alternator, power steering pump, air conditioning compressor, or emission air pump output. A belt that is too tight places a strain on the bearings in the driven component.
Fig. Fig. 1: There are typically 3 types of accessory drive belts found on vehicles today
Fig. Fig. 2: An example of a healthy drive belt
Fig. Fig. 3: Deep cracks in this belt will cause flex, building up heat that will eventually lead to belt failure
Fig. Fig. 4: The cover of this belt is worn, exposing the critical reinforcing cords to excessive wear
Fig. Fig. 5: Installing too wide a belt can result in serious belt wear and/or breakage
Replace any drive belt that is glazed, worn, cracked, or stretched to the point where correct adjustment tension is impossible. If two belts are used to drive a component, always replace both belts when replacement is necessary. After installing a new belt, run the engine for ten minutes, shut OFF the engine and recheck the belt tension. Readjust if necessary.
ADJUSTMENT
See Figures 6, 7, 8, 9 and 10
Fig. Fig. 6: Engine belt tension chart-2.2L engines
Fig. Fig. 7: Engine belt tension chart-1987-89 2.5L engines
Fig. Fig. 8: Engine belt tension chart-2.6L engines
Fig. Fig. 9: Engine belt tension chart-1990-93 models
Fig. Fig. 10: Engine belt tension chart-1994-95 models
Two popular methods of checking drive belt adjustment are; the Belt Tension Gauge Method and the Belt Deflection Method. The former requires a special gauge and the latter requires a straight edge and scale or just a good eye for measurement. The deflection method will be used in the following belt replacement instructions. A rule of thumb for checking belt tension by the deflection method is to determine the midpoint between two pulleys of the drive belt and press down at that point with moderate thumb pressure. The belt should deflect to the measurement indicated in the following installation procedures. Adjustment is necessary if the belt is either too loose or too tight.
WARNING A belt adjustment which is either too loose or too tight will eventually damage the accessory that belt is driving. A too loose adjustment allows free-play in the belt which could transfer a whipping motion or shock to the accessory drive pulley. Similarly, a belt which is too tight will preload the accessory bearings, leading to early failure.
REMOVAL & INSTALLATION
See Figure 11
Raise the front of the vehicle, support on jackstands and remove the lower splash shield if access is hampered due to space limitations when changing drive belts.
Fig. Fig. 11: Support the vehicle, then remove the lower right side splash shield for access to the drive belts
2.2L Engines
A/C COMPRESSOR DRIVE BELT
See Figures 12, 13 and 14
Fig. Fig. 12: A/C compressor drive belt adjusting points-2.2L engines
Fig. Fig. 13: Loosening the locking screws for A/C compressor drive belt removal
Fig. Fig. 14: Removing the A/C compressor drive belt from under the vehicle
  1. Loosen the idler pulley bracket pivot screw and the locking screw.
  2. Remove the belt and install a replacement.
  3. Using a breaker bar and socket apply torque to the welded nut provided on the mounted bracket to obtain proper tension.
  4. Tighten the locking screw first, followed by pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR DRIVE BELT (CHRYSLER TYPE)
See Figures 15 and 16
Fig. Fig. 15: Alternator belt adjustment-2.2L engine
Fig. Fig. 16: Loosening the locking screw for alternator drive belt removal
If removal of the alternator belt is required, the A/C belt must first be removed.
  1. Loosen the pivot nut, locking screw, and the adjusting screw.
  3. Adjust to specification by tightening the adjusting screw.
  4. Tighten the locking screw to 25 ft. lbs. (34 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (41 Nm).
ALTERNATOR DRIVE BELT (BOSCH TYPE)
  1. Loosen the pivot nut, locking nut, and adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (34 Nm).
POWER STEERING BELT
If removal of the power steering belt is required, the A/C and alternator belts must first be removed.
  1. Loosen the locking screw, and pivot screw.
  3. Install a 1 / 2 in. breaker bar into the pump bracket slot, apply pressure with the breaker bar and adjust the belt to specification.
  4. Tighten the locking screw first, then the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
AIR PUMP DRIVE BELT
See Figure 17
Fig. Fig. 17: Air pump belt adjustment-2.2L engines
When servicing the air pump, use the square holes provided in the pulley to prevent camshaft rotation.
  1. Remove the nuts and bolts retaining the drive pulley cover.
  2. Remove the locking bolt and pivot bolt from the pump bracket, then remove the pump.
  3. Remove the belt and install a replacement.
  4. Position the pump, then install the locking bolt and pivot bolt finger-tight.
  5. Install a 1 / 2 in. breaker bar into the bracket assembly (block the drive pulley to prevent camshaft rotation), and adjust the belt to specification.
  6. Tighten locking bolt and pivot bolt to 25 ft. lbs. (35 Nm).
2.5L Engines
AIR CONDITIONING COMPRESSOR
See Figure 18
Fig. Fig. 18: Drive belt adjustment points-2.5L engines
  1. Loosen the idler bracket pivot screw and the locking screws to replace, or adjust belt.
  3. Adjust the belt to specification by applying torque to weld nut on the idler bracket.
  4. Tighten locking screw first, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR BELT
See Figure 18
If replacement of the alternator belt is required, the A/C drive belt must first be removed.
  3. Adjust the belt to specification by tightening the adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (35 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (40 Nm).
POWER STEERING PUMP
See Figure 18
If replacement of the power steering belt is required, the A/C and alternator belts must first be remove.
  1. Loosen the locking screw and pivot screw to replace, or adjust the belt.
  3. Using a 1 / 2 in. breaker bar positioned in adjusting bracket slot, adjust the belt to specification.
  4. Tighten the locking screw followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
2.6L Engines
ALTERNATOR/AIR CONDITIONING COMPRESSOR BELT
See Figure 19
Fig. Fig. 19: Drive belt adjustment points-2.6L engines
  1. Loosen the locking screw, jam nut, and pivot nut.
  2. Loosen the adjusting screw.
  4. Adjust the belt to specification by tightening the adjusting screw.
  5. Tighten the locking screw followed by the pivot nut. Tighten to 16 ft. lbs. (22 Nm).
  6. Tighten the jam nut to 21 ft. lbs. (28 Nm).
POWER STEERING PUMP BELT
See Figure 19
If replacement of the power steering belt is required, the alternator and A/C belt must first be remove.
  1. Loosen the pivot screw, and the locking screw.
  2. Remove the timing pickup.
  4. Install a 1 / 2 in. breaker bar in the adjusting bracket slot, torque to specification.
  5. Tighten the locking screw, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
  6. Install the timing pick-up, and tighten to 160 inch lbs. (18 Nm).
Jul 26, 2012 | 1994 Dodge Grand Caravan
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Aug 19, 2010 | Toro Garden
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Need to replace belt tensioner pulley
no remove the belt remembering the belt on how it went on remove belt then remove the tensioner usually one bolt and replace tensioner then replace belt the same way it came off
Mar 27, 2009 | 1996 Mercury Sable
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
I need instructions on replacing the timing belt
1. Remove the Alternator Belt.
2. Remove the Water Pump Pulley
3. Remove the Air Conditioner Belt and Power Steering Belt.
4. Remove the Crankshaft Pulley.
5. Remove the timing belt cover
6. Remove the timing belt tensioner pulley.
7. Remove the Timing Belt.
8. (If Replacing) Remove Idler Pulley.
Installation is reverse of removal. Keep a close eye on the timing marks on the cam sprockets to make sure you don't knock anything out of whack.
I would strongly recommend replacing the water pump while you are replacing the timing belt. (The water pump usually comes in the timing belt kit.) Otherwise you are going to have to do this all over again when your water pump goes out. Good Luck.
Nov 10, 2008 | 2004 Hyundai Tiburon
How to replace a serpentine belt on a ford taurus 2002
just replaced serpentine belt on my 2000 taurus with the push rod engine, first remove the plastic radiator recovery bottle.
next using a 15mm closed end wrench, remove the tension from the aerpentine belt. paying special attention on the routing of the belt prior to removing. Remove the old belt. Reverse this procedure to replace the belt.
Aug 11, 2008 | 2000 Ford Taurus
Reel to reel belt replacement
ITS been a long time since I replace BELTS for VCRs and REEL to REEL , what I suggest is , if youre very handy with tools and know your way around electronics, you can perform the replacement of the belt, open REEL TO REEL to access where BELT is located , study how is install , and remove ONLY the parts thats blocking you to remove OLD belt,memorize the order which you remove the neccesary parts
then install new belt , and install back parts in the order that was remove , hope this helps , good luck , AJ
May 25, 2008 | Audio Players & Recorders
Thermos Nissan Compact Beverage Bottle FBB500 Grinder Logo
Top Thermos Coffee Makers & Espresso Machines Experts
Paul Carew
Lisa Demont
Lisa Demont
Level 1 Expert
Lamar Holden
Lamar Holden
Are you a Thermos Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
