Question about HP LaserJet 1320 Printer
1320n marks along left side of paper
I have a 3 month old toner, and last week I notoced small dots or flecks along the left side , basically top of sheet to bottom, of every piece of paper that comes out of the printer. Any ideas?
  • HP Expert
  • 141 Answers
Repetitive defects are caused by either a ding on the drum in the toner, a scratch or dirty transfer roller, or scratched or dirty heat roller in the fuser, Last but not least is dirty exit roller. the first step to any print quality defect is to cahnge the toner cartridge. Good Luck!
Posted on Sep 17, 2008
I just read that random dots being printed on the left side of all my documents means that i need to change the toner. I just changed the toner last week or the week before. Is this something that I call...
Well not often the problem is same, usually the toner cartridge will have 2 bins 1 is the hopper which holds the un-used powder and the other is the Waste toner bin which holds the waste powder. When it is full and there is no place to escape then the powder spills on the paper. But if this happens then you can just bang your toner lightly and in this was the air pockets in the powder is clear and spill will stop automatically.
Jul 06, 2011 | HP LaserJet 1020 Printer
Ink dots on right side of paper
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Apr 15, 2009 | Dell 3000cn Laser Printer
Brother printer problem- "noise" on printed paper
when you open the front door to replace your toner. The part that you put your toner in is the drum unit. pull that out. Remove the toner cart. blow the unit out.
On the top of the drum unit there is a blue or green slide lever move the lever back & fourth 15-20 times.
re blow out the machine with drum unit out.
Reinstall the drum,
make 5 copies ( 1st feow will be bad hope thay will get better )
If not need to determan if the drum is bad or the fuser asm is cuasing the problum.
( part that melts the toner on to the paper )
Need to do a 1/2 print test.
1. make a copie or do a report
2. when the paper is 1/2 way thrugh the machine but not in to the fuser open front cover.
( may need to tray a coupel of times to do ot right )
3 look at the paper see if marks are on the paper.
( If not then the fuser is bad. if the marks are there the drum is bad )
Hope this help's
Feb 11, 2009 | Brother MFC-8220 Fax
let me know the make & model. there may be a toner dposit in the paper path.
Jan 26, 2009 | Office Equipment & Supplies
2 lines down the right side of paper - sharp 1641 CS copier
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Dec 11, 2008 | Sharp AL-1641CS Laser Digital Copier
My brother hl 2040
Your not resetting the toner reset lever. It's on the left end (not the fill cap side) of the cartridge. If you have a resettable cartridge on the left end you will see to white pieces. One round and one like a lever in a half moon slot. We will be addressing the lever in the half moon slot only. The lever on a used cartridge will be at the 3 O'clock position. Remove the two screws from the end cap and then move the gear to the 11 O'clock position. Put the end cap and screwss back on. Put it back in the printer and close the door. When the printer powers up it will sweep the lever across the sensor and reset the toner level to full.
Hope that helps you.
****Important Note****
When refilling, make sure you dump out and clean ALL OF THE OLD TONER from the cartridge before refilling. Brother reuses it's old toner putting it back into the fresh toner supply (along with debri) and slowly contaminates it's supply with paper dust and talc from the paper.
If you don't clean out the supply hopper well before refilling, it will quickly mix your new toner with the old toner and more quickly contaminate the entire supply. USE GOOD PAPER, NOT CHEAP PAPER and your supplies and refills will last much longer.
Jul 27, 2008 | Brother HL-2040 Laser Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Dots when Printing
Replace toner then you cam make sure wether problem with toner or printer.
May 22, 2008 | HP LaserJet 1020 Printer
What does a "symbol" stand for?
yep simple problem ..
step 1 : close the machine (power off)
step 2 : push the button in the right side (up) of the macheine (means with your left hand)
step 3 : open the cover and pull the toner
step 4 : normally you shoul find a remaining piece of paper not correctly printed stuck inside
step 5 : take it off..power on ..there you go :)
dr prince..
Apr 18, 2008 | Lexmark E232 Laser Printer
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP LaserJet 1320 Printer Logo
258 people viewed this question
Ben Johnson
