Question about Apple iPod touch
How much is the lcd of this unit... - Apple iPod touch
    Problem Solver:
  • 6 Answers
If you go to google.com upper left there are buttons click shopping and type Lcd of 8gb ipod touch. It will show a list of online places you can buy them from. They range from $1-20 depending where you get it from
Hope i helped
NoobTerminator aka Manchild
Posted on Mar 28, 2011
Lcd light has gone on MCF 210C Brother machine,
Possible failure of the power supply unit or the LCD unit of the printer. You will need to remove the power supply and check the voltage feed to the mother board and the sub panel LCD unit.
If there is supply to the unit then the LCD panel is faulty, if not the mother board has errors as it fails to communicate to the panel.
May 07, 2011 | Office Equipment & Supplies
Does not work. I think it was dropped.
Sorry the unit itself probally have a major or micro cracks into it PCB board.After it repair by a tv tech.The unit still could be also have bad or damges picture to the LCD screen panel too itself.The unit was drop hard or high up like from 3 or 4 feets?Not worth and a wast of the money for a repair for a drop electronic equipments with a LCD screen panel.Unit now only have 50/50 chances for the unit to work correctly again or without the unit LCD screen panel to have damages or picture to the LCD screen panel be effected.Best just buy a new one.
May 03, 2011 | Radio Shack Accurian APD-3955
The LCD screen is not working ??
Possible failure of the LCD display unit. You will need to open the camera to confirm, if there is no fault in ribbon leads , no fault in the connections and there is power on the LCD display unit without any display the unit is faulty.
If the camera is working otherwise in all areas then the LCD must be replaced.
Feb 09, 2011 | Canon PowerShot SX20 IS Digital Camera
Cost of display for s501
Jan 21, 2011 | Lands Phones
Half the screen is blinking? What Can I do to fix it?
Need LCD Panel replaced
LCD PANEL UNIT PER SERIAL NUMBER:
******1-802-491-12******
SERIAL NUMBER FROM 8000001 TO 8199999 and FROM 8500001 TO 8599999 UNITS
******1-802-491-31******
SERIAL NUMBER FROM 8200001 TO 8499999 and FROM 8600001 AND UP UNITS
Nov 17, 2010 | Sony KDL-46XBR5 46 in. LCD HDTV
I have a samsung 15 inch LCD TV. When I turn the
kcs36dd, Lcd TV's also have, just like LCD monitors, an AC to DC voltage power supply. It is called a "switch-mode-power-supply" and generates the DC voltages required for all the other important electronic circuits inside the unit. 98% of all 14" to 22' lcd panels have backlighting provided by "cold-cathode-fluorescent-lamps" (CCFL) that produce WHITE LIGHT so you can see all the pretty colors that the glass LCD PANEL produces on the screen. The INVERTER circuit requires 12vdc to 20vdc from the SMPS to convert into 500 to 1000v ac to light-up the CCFL's. IF the SMPS detects a FAULT CONDITION with itself or the INVERTER it will go into what is known as FULL or PARTIAL SHUTDOWN MODE to try and save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. lmistyrel on aim.com I could give you more assistance if you had provided following informatiom.
1. How old is the unit? 2, Approximate total "ON" hours unit has? 3.Has unit failed within the WARRANTY period? 4. Will SAMSUNG do a cash+old unit swapout because of PREMATURE FAILURE? 4. Do you know enough to do a unit TEARDOWN and inspection to possibly determine ROOT CAUSE of SMPS/INVERTER failure? 5. Can you handle a soldering iron and solder to make DIY repairs to unit. 6. Since your unit is just a little more complex than a LCD MONITOR, have toy viewed on YOUTUBE short video clips of "LCD monitor disassembly" or "LCD monitor repair" for the most common cause of BLACK screen complaints? If further assistance is required do additional post to original. 12fixlouie aka louie12fix on fixya
Dec 05, 2009 | Samsung 153b-sliver (Silver) 15 in. Flat...
The images displayed are purple. I sometimes solved the problem by adjusting the focus. Now it remains purple all othe time.
Hello...The problem you're describing is related to the green lcd and most likely the main board(green channel). If the focusing removes the purple(you have *that* much dust in the unit?) then it *is* dust. You should be able to focus on the dust particles twice--dust on the front of the lcd and dust stuck to the back of it. I'm gonna give you the color table so you know what to look for and what you're seeing. Red LCD=cyan(baby blue) onscreen; Green LCD=violet(purple) onscreen; Blue LCD=yellow onscreen
If you have a lot of dust(and the green lcd usually is the main culprit by the design of the lcd panels around a glass "cube" internally) you might try blowing some air into the unit when it's cool. However, the unit probably needs a good cleaning--remember to clean the dust filter! To properly clean the unit, a trained tech will have to perform the job. The lcd panels are DELICATE and precisely positioned for displaying a sharp image.
Sep 18, 2009 | Dukane ImagePro 8755A Multimedia Projector
No indication of power to the unit. I opened the unit and removed the cable connecting the main board to the LCD controller board. I disconnected it from the LCD controller board side. When power is...
If you hear a flickering sound the power board is bad .However since you have found the lcd board to be faulty you might as well replace it.Look for it on line by part number.Or to save yourself some headache use a good board from a working monitor.
Good luck
Sep 16, 2009 | Acer AL1923 19" Monitor
The LCD only works in a certain position
Flat cable connecting LCD unit to main board broken. Whole "shaft unit" have to be replaced ( LCD hinge with flex cable). Panasonic part #
LSEP8449A1
Nov 14, 2008 | Panasonic SDR-H40 HDD Camcorder
Sony LCD HS73 LCD goes blank 2sec.
defective backlight inverter unit. Replace the inverter unit or chek if there is any dry joints inside the unit.
Apr 02, 2008 | Sony SDM-HS73P 17" LCD Monitor
Apple iPod touch Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
