Question about Dryers
Have whirlpool new dryer that flashes af had duct cleaning company come in and clean the they took apart all pipes going to the roof dryer still flashes air flow
  • anthony gatto Mar 28, 2011
    all the info i just received is everything i already know the air flow signal comes on after all that work was done
  • anthony gatto Mar 29, 2011
    THE DRYER NO IS WED7400XW
  • Dryers Master
  • 19,396 Answers
Hi.
The air flow error comes on when the thermistor located in the air intake overheats and opens the circuit. If the thermistor is defective you get this problem.
If the thermistor is fine and air intake and filter are OK, then you may have a defective control module. The control module is expensive. Before replacing the part check also wiring to thermistor, ensure that the fan is OK, and test the heating element (if electric) to ensure that this is not staying always on because of a contact to ground.
I can be more specific if you give me the appliance model number. Please be patient for answer time. Mail support does not work in real time like the chat. Thanks for understanding.
Regards.
Ginko
Posted on Mar 28, 2011
  • Ginko
    Ginko Mar 29, 2011
    Hi.
    If there is no obstruction and vent is working, replace the Dryer thermister
    - Located on the blower housing next to the thermal fuse. If that does not fix the issue, either there is a ventilation problem that has been overlooked in your first check, or the control is failing (quite uncommon).
    The part is nr 43 in diagram below, click on the picture to enlarge:
    Here all parts and diagrams for your appliance: WED7400XW0.
    Regards.
    Ginko
  • 4,323 Answers
Hi
If the vent is secure and free from any debris at the back of the appliance and there is no obstruction outside of your home then make sure that the lint trap is clean. Also check this link for more information. Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott Mar 28, 2011
    I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
    Daniel
No air at vent
Sound like you need to replace the heating element.
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Jan 01, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Dryer not drying-the sceen has af flashing please help..whirlpool cabrio
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Thanks for using FixYa.
Sep 17, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
When I turn the Dryer on there is the letters AF start flashing it is running and drys the close but it takes a lot longer than it did when I got it.
I've seen the AF code twice now on my Whirlpool Cabriolet Dryer (wed6400sw1). The first time, we thought it stood for "Auto Fluff", a cycle to keep the clothes wrinkle free...We soon realized the dryer was getting a lot hotter than it ever did before and until I checked the vent stack from the roof, I had no idea that the pipe was blocked with a build-up of lint. I cleaned the pipe from top to bottom by taking it apart wherever I could using a vacuum and every hose extension I could get my hands on. I duct taped these together so I didn't drop it somewhere that I couldn't reach!
The second time we saw the AF code was this weekend. First, I verified the vent pipe was not clogged again. (a good quick test for this is to disconnect it from the back of the dryer and run it unconnected to see if the AF code fires) After some online research, I started taking it apart the back to maybe replace the thermistor or the thermal fuse shown above.
I noticed an odd little piece of ceramic tubing had fallen down to the base of the dryer pan. So I decided to take the heater core apart to have a look. Sure enough, I found my problem. My dryer has two separate groups of springy looking heater wire. You can see that part here as well as the little tube I found. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-element-item-number-ap3953732.aspx It turns out that ceramic tube is an insulator allowing for the two heating elements to exist without touching since they are both powered from the same starting wire point.
Well, my AF code (which is really just telling you the dryer is getting too hot) was being created due to a broken wire which caused the two units to fuse together. It must have been getting really hot. It also had welded itself to the metal backing structure.
I carefully removed the broken wires from the heater element and reassembled to test. Sure enough, it works good again and no AF code, but I bet it doesn't heat as much since I removed one half of the element. I'm going to pick up a replacement heater element tomorrow from the local parts store to restore it like new.
Hope this helps someone!
Mar 23, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool dryer Cabrio 6 months old. message on screen is "AF" what does that mean?
Code AF means the air flow is blocked.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 07, 2011 | Dryers
The heat goes on temporarily and then shuts off
The most common problem is a clogged vent.
To do this, unplug your dryer and move the dryer out enough so you can get to the dryer duct easily. Most dryer ducting is flexible like a big slinky with a vinyl(older style no longer used) or metal type covering. There are some that are rigid as well.
Remove the duct from the dryer and where it attaches to the wall. Use a shop vac or house vac with attachments and insert through the wall and vacuum as much as you can. I use a shop vac since it has the blowing capability and I can check if air is coming out of the dryer vent located outside after I vacuumed it out. It is good to get confirmation that air is coming out of the vent. Check the dryer where the duct was attached and vacuum anything that is in there. Put everything back in reverse order and give it a whirl.
There are some homes,condos,and apts the have the hidden ducting go up the wall and through the roof. If this is the case, you will need to go on top of the roof and find the vent pipe. This pipe will have some sort of cap on it to let the hot air out but keep other elements out. Since you mentioned the heat goes on for a bit, have someone go on the roof (use caution) and have someone else turn on the dryer. The person on the roof can check the vent pipes with his hand for heat.
Nov 16, 2010 | Whirlpool Dryers
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
The dryer on gets warm and takes a long time to dry clothes
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Jun 28, 2009 | Whirlpool LER5636P Electric Dryer
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Water coming out bottom
ANOTHER THING TO CHECK IS IF THE DUCT IN THE WALL IS PLASTIC OR METAL. IF IT IS PLASTIC, IT WILL CONDENSATE INSIDE THE PIPE BECAUSE THE PLASTIC REMAINS COOL AND CAUSES WARM, MOIST AIR FROM THE DRYER TO CONDENSATE IN THE INTERIOR WALLS. WITH A VERTICAL RUN, IT WILL FALL BACK TO THE BOTTOM AND PUDDLE THERE. IF IT IS METAL, AND GOES THROUGH THE ROOF, MAKE SURE THERE IS A CAP ON THE OUTSIDE PIPE TO PREVENT RAIN WATER FROM COMING DOWN INSIDE. CHANCES ARE THAT IF YOU HAVE WATER INSIDE THE PIPE, THE ENTIRE PIPE IS LINED WITH LINT FROM TOP TO BOTTOM. YOU WILL NEED TO RUN A CLEANOUT BRUSH THE FULL LENGTH OF THE PIPE.
Mar 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
