Question about Hotpoint NBXR463EBWW Electric Dryer
Hotpoint dryer model NBXR463EB0WW - the belt broke while in operation making a loud bang. I have the new belt but when installing I cannot get the belt to tighten. The idler pulley is loose-just wiggles back and forth - do I need to order a new idler pulley or is there a spring which has come off which needs to be replaced - I cannot find a spring in the dryer but have not taken out the drum. If the pulley needs to be replaced can you also forward instructions for doing so. Thanks for any help you can give!
  • 1 more comment
  • jivjohnson Mar 28, 2011
    Should the idler pulley be loose or tight as I have not found a way to have it stay in position it just wiggles around.
    Thanks.
    The pulley and arm look to be OK only moves about easily. Is it possible that I have the wrong belt? There is about an inch of give around the drum when installed. As I do not have a manual the belt I ordered online was a GE/Hotpoint belt WE12M29. Can you verify that I have the correct belt please.
    Thanks.
    As the idler pulley wobbles and no longer creates tension on the belt I assume it will need replacing - can you forward instruction on replacement of this part for my dryer.
    Thank you.
  • 1,998 Answers
First click this link and watch this video http://www.youtube.com/user/RepairClinic?v=zpUqCrLaI7g&feature=pyv&ad=5544346181&kw=dryer%20belt&gclid=CI7yoK7z8qcCFRNrgwodjlNFbg its basicly the same repair for your machine the belt goes around the pulley and you pull the pulley back that adds the tension to the belt when ever you repair the belt in the machine you should also replace the pulley and the rollers as well this usually comes as a kit but if you dont ask for it as a kit most places break the kit in to three seperate pieces to make more off the sale notice in the video how the belt goes around the pulley if you have any further questions message me back i will be flying this week from hawaii to the east coast and will be returning on thursday so if i dont see your post by tomorrow i will message you back on thursday if you have any further questions Thanks Rick
Posted on Mar 29, 2011
    Brigadier General:
  • 3,513 Answers
Hi
While sliding the old belt off of the drum and pulleys loop one end of the new belt around the drum. Adjust the belt so it fits into the middle of the belt groove.Now Position the other end of the belt around the motor pulley. Pull the idler pulley toward you. Position the belt along the groove of the idler pulley. Release the idler pulley to make the belt tight.
Please check the bellow instruction for more details.
First unplug the electrical cord before replacing the dryer belt.Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
Also check this bellow links to have an in-depth knowledge related to your issue:-
http://www.ehow.com/how_5189091_replace-belt-electric-hotpoint-dryer.html
http://www.ehow.com/how_7357167_install-hotpoint-dryer-belt.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 28, 2011
  • Aparajita Batabyal
    Aparajita Batabyal Mar 28, 2011
    Hi
    A dryer's idler pulley wheel serves to help the belt to rotate the drum. If it becomes worn, or if it breaks, then the drum will be impeded in its attempts to tumble and rotate. Inspect your dryer's idler pulley wheel and idler pulley arm. If it is excessively worn, has little cracks, or is broken altogether, you will have to replace it.
    With your dryer opened up, you'll notice that the belt loops over the drum, under the idler pulley wheel, and around the motor's drive pulley. Tension is applied to the belt by the idler pulley wheel that sits on a moveable arm.
    You can now reach into your dryer, to the belt. Be weary of any sharp edges on the inside of the cabinet and the interior supports. Tug on the belt. Is should be tight, with only a little give when you tug on it. Push the idler pulley towards the motor so that you can release the tension on the belt. Now you can remove the belt and inspect the idler pulley wheel.
    Look closely at the pulley wheel. Take note if it is noticeably damaged, or if it is no longer maintaining the required tension. Spin the pulley wheel. It should turn smoothly and quietly, without any wobble. If your dryer's idler pulley wheel assembly is damaged, excessively worn, or no longer functioning as it should, it will have to be replaced. Depending on your dryer model, you may be able to replace just the wheel, or the entire idler pulley wheel and idler pulley arm assembly.
    Thanks for contacting fixya.com
My Hotpoint tl61p tumble dryer made a loud bang, and now will not work, the timer justs buzz's? can anyone help please?
The load bang you heard was the idler pulley slamming into the frame more than likely. this is because your belt broke removing the tension suddenly. Put a new belt on and you'll be fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Hotpoint Dryers
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
I was drying my clothes and heard a loud bang and the dryer started making a weird noise so i shut it off then turned it back on and it kept doing it then the drum just stopped moving completely
The sound was probably the spring tensioner hitting the chassis when the belt broke.
the dryer needs a new belt. Without knowing the model, hard to describe disassembly
You might be able to get a good maintenance tech off hours who can do this reasonably
by checking on Fixya or Craigslist as it can be a bit of a nuisance. Approximately
an hour to do and around 7 to 10 dollars for the belt.
Jul 31, 2011 | Dryers
Hotpoint condenser dryer overheating. Heard a loud bang fom dryer then smell of burning. Checked to see if power cable was melting but was ok. The back of the machine was red hot though thanks for any...
1st check see if drum turning if not could be belt.Next heater circuit, check replace thermostats, Make sure filter clean and exhaust ok before above......
Mar 22, 2010 | Dryers
Out hotpoint dryer is 8 years old and juist
Sounds like the drum bearing or shaft is worn.
Remove rear panel of dryer, you should see the drum shaft, check for wear here.
Jan 17, 2010 | Hotpoint Dryers
The belt broke and i need to know how to put a new one on
The front of the dryer has to be removed to replace the belt. Best I can do is send a link to an exploded view. Unplug remove the top then the front slide the belt over the drum and make sure it will fit to the motor install the fromt tuen the drum by hand to make sure it turns freely. Slipthe belt over the motor pully turn again making sure it is smooth. replace the top and test the operation.
Aug 12, 2009 | Hotpoint Dryers
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Dryer belt broken
http://www.pcappliancerepair.com/model-display.php From what I see, you have to remove the front, and maybe the drum to get at the belt. See what instructions come with a new belt.
May 12, 2009 | Dryers
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Hotpoint NBXR463EBWW Electric Dryer Logo
152 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
