My MacVision MP007 can't load a DVD's. I can try the same DVD many times, the MP007 reads it 1 out of 5 times only. When the MP007 actually plays a DVD it freezes at different places. We cleaned the lens, made sure the CD's are cleaned. Made sure the unit is stable on a table in house (not in a car moving). Tried many different DVD's, tested these DVD's in another DVD player to make sure they were not dammanged. My MacVision MP007 was manufatured in Sept 2005; s/n SC051018146, bought at Canadian Tire. Thanks for the info. Peter O'Cain Tel Cell 514-513-9702
SOURCE:
SOURCE: Suddenly "cannot play this disk" on Sony DVD/CD..every DVD...CD's work!
I have the same problem. I have a 5 year warranty from the company I purchased the unit from. I am not sure if they will replace it or not. I am reluctant to buy another one with this known issue. We have enjoyed the unit for nearly 3 years with no issues.
Posted on Nov 23, 2008
  • 1139 Answers
SOURCE: phillips dvd player
OK lets start off by getting rid of the CD lens cleaner (CD cleaners do more damage then good). Now first we need to clean that lens with a DVD lens clearner (finer cleaning surface). Try to run the DVD cleaning disk twicw (no more) and try to play a DVD. If this does not work. You may have to test the laser power. get a schematic for the DVD that you have, and use it to let you know the specific power measurement of the power, This is done by using a laser power meter, you may not have one, so this becomes a moot point, but on the off chance that you do, use the laser power meter to measure the laser energy and make sure it is to specs as seen on the schematic. If you do not have a laser power meter., well I hate to tell you this but you may have to get a new unit. See the problem is the process of fixing this problem is simple if you have the right equipment, but if you don't you are at a disadvantage.
Posted on Sep 11, 2007
  • 236 Answers
SOURCE: Tray opens but won't close or closes but doesnt play
deferctive laser lense already. try to replace if more economical than buying new unit
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Posted on Feb 01, 2009
seabelow
  • 95 Answers
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Posted on Jun 12, 2009
I need the remote control code for the macvision MP007 portable dvd player
4567 4406 4390 4403 4582. These are the codes to check. If you wish to get more, http://electrohelponline.blogspot.com/
Aug 12, 2013 | Televison & Video
Mac vision head unit got sound but no picture help please
I have same problem :s
Music plays fine... But no visuals show on the screen.
When playing a dvd you can here the film but the screen is obviously blank!!??
Dec 11, 2010 | Nextar MacVision MP1607 Car DVD Player
Dvd takes 1 min loading ,then comes up can't read disc. I have tried to reset, then tried dvd again still takes long time to load and plays dvd once or twice for about a minute then stops, then goes back...
Optical lens needs to be cleaned with good quality cotton swab gently that will solve your dvd problem.
Unplug dvd player, take off top cover by removing its screws and clean optical lens.
Thanks.
Oct 30, 2010 | Sony Televison & Video
Macvision MN2607 signal problem
Hi and thank you for using fixya:
If you are having trouble getting signal please check if any object is obstructing the view of the sky from your signal receiver.
Thanks good luck
Jul 26, 2010 | Nextar MacVision MP1607 Car DVD Player
Im looking for a used macvision mp007
I own a macvision mp007 portable dvd player I am looking for the back seat support and a car adapter.
I want to connect this for my son when we drive, he is 5 yrs old born with autism.
I think it would look great in my car, and some even better once I connect it to my car sound system
May 16, 2010 | NexxTech DP3222 DVD Player
Mp007 dvd portable
First thing is to clean the laser with a disc cleaner kit to see if that cures fault. If not then can suspect mechanical with motor or drive
Jan 06, 2010 | Nextar MP-1607 Portable DVD Player
Denon 2910 CD player malfunctions
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Nov 04, 2007 | Denon DVD-2910 DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Televison & Video Logo
329 people viewed this question
Top Televison & Video Experts
Ekse
