Question about Linksys Wireless-G Broadband Router
I bought a wireless Linksys wireles- G router used for 5.00. They said that it had a weak signal. I hooked it up and sure enough I have a weak signal. So weak that it does not connect to anything but there is a small signal. Any thing I can try? What could cause that weak signal? Does it need repaired and if so where? Thanks, Wayne
    Sergeant:
  • 231 Answers
If the router is too far away from the computer it will advise you of insufficient signal, You can always purchase a wifi antenna from www.Amazon.com.
Posted on Mar 28, 2011
  • 85 Answers
I made mine into a range expander with this information
http://lifehacker.com/#!5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
If you up to the challenge and can follow instructions, takes about 30 min to do.
When you put on the new OS for the router you can up your signal too.
I have bought linksys wag200g **** its not working properly when i use wifi on my mobile.... and device disconnected after every 1 or 2 minutes.. i have ADSL connection......
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 18, 2012 | Linksys WAG200G Router
Just hooked my wireles n router up to my desktop but how do I get connection to my netbook or ipod
on your desktop, log in to the router (linksys is usually 192.168.1.1) through your web browser
the default password should be admin admin for username and password.
look to see what your ssid is.
on the netbook and ipod, go into your wireless settings and connect to the same ssis as before.
Jan 18, 2010 | Linksys Wireless-G Broadband Router
Cannot connect to internet wireless
Please get to the router configuration console (Router GUI on 192.168.1.1) and click wireless => Try changing the channel number and if reboot the router and test for all 11 channels, incase if there is no diffrence please follow the steps below:
Wireless => Advanced wireless Settings => Change the following:
1) Beacon interval = 50 instead of 100
2) Fragmentation Threshold = 2306 instead of 2346
3) RTS Threshold = 2307 instead of 2347
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless b router
Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
Jun 29, 2009 | Linksys Wireless-G Broadband Router
Password setup problems
ok this is simple but at the same time kinda confusing open an internet window and type in 192.168.1.1 the password on defalt is going to be eather password or admin and the username is admin after you get past the login it should take you to a setup page click on wireless at the top  after you click on wireless just under that click wireless security thats the settings to change the wireless security in there you can chose what type of secutiry you want i normaly use wap2 on TKIP after setting those type the password you want after that save it and close the window on all the computers that use wireless your going to have to disconnect them and reconnect them from the network it will ask for the password enter it and make sure it saves the password and your set if you have any problems in the process let me know if be glad to help
Please rate this
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Do I have to have a wireless roator for my laptop?
you can buy a wireles linksys usb for your lap top and have a wireless router linksys stationary and the lap top usb ..... will pick up the signal for your lap top, i have a usb port linksys and it works great, but u do need a router in your home to pick up the signal
Jan 21, 2009 | Dell Latitude 100L Notebook
Wireless Network
You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
Hope that helps........
Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Compaq Evo with wpc54g v.1 wireless adaptor
hello!
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys Wireless-G Broadband Router Logo
331 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
