Question about Brother HL 1440 Laser Printer
Internal Part I was flushing with air the interior of the printer to remove excess if dust but some piece fall out. I just want to know where this piece come from. I can send you the photo of the piece. thanks
  • 138 Answers
Here's a link to the complete free service manual for your Brother HL-1440 printer. Look the parts section starting aroungd page 228. It will show you just about every part in the machine. Once you've located what it is, the earlier sections of the manual will assist you in properly replacing the part step by step.
Hope that helps you.
Posted on Aug 26, 2008
TROUBLE SHOOTING FOR HPDESKJET 940C
You can try the following steps....
Turn on the printer and lift the top cover. Wait for the print cartridges to move to the center of the printer. Tilt the cartridges forward and carefully lift them out of the printer.
Dip a cotton swab in warm water and clean the metal connectors on each print cartridge thoroughly to remove all paper dust and ink residue. Continue cleaning the cartridges with new swabs until the swab comes away clean.
Vacuum the interior of the printer with a small vacuum cleaner like the kind used to clean and service computers. Continue cleaning the printer until no more ink residue and paper dust are found in the interior.
Wipe the inside of the printer with a soft cloth to remove any remaining residue. Reinsert the print cartridges into the printer, making sure they are secured with a click, and close the lid.
Remove all paper from the paper tray and flip the tray down so you can clearly see the inside of the printer. Direct a flashlight into the printer interior and look for any torn pieces of paper.
Grasp any torn paper firmly with the tweezers and pull it straight out of the printer. Examine the printer interior again with the flashlight to ensure there is no more jammed paper.
***If you need any technical help on printer then you can reach at here
Mar 06, 2013 | HP DeskJet Office Equipment & Supplies
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper unable to feed
Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
All the Best..
Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
How do you fix a paper feed problem in a Cannon iP1600
  1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
  2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
  3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
  4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
  5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
Good Luck!
Aug 23, 2010 | Canon PIXMA iP1600 Printer
One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
May 30, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Unable clean
Cleaning a Printer Benefits: When your print job isn’t up to par, you can get rid of smudges, white lines and reduce paper jams by simply cleaning your printer. Of course, the real benefit of cleaning is that it saves you money by prolonging the life of your printer! Your first step in cleaning a printer is always to check your manufacturer’s documentation. If you don’t have a written manual, most manufacturers provide tips on what not to do and provide support for even older printer models on their web sites. Use only the cleaners that your manufacturer recommends and clean only recommended areas of your printer.
Tip: Search for terms like printer maintenance, printer cleaning, and troubleshooting.
Tip: Always check both your manufacturer’s documentation and warnings and advisories on cleaning products to be sure they are compatible with your printer and the cleaning job that needs to be done.
Cleaning the Outside of Your Printer
1. Turn your printer off before cleaning.
2. Clean the outside of your printer with a moist, lint-free cloth. Flour sacking or 100% cotton white t-shirt material works well.
3. Usually a solution of one part vinegar and one part water is safe to use, but when moistening a cloth, be sure to wring out all the excess. Distilled or RO (reverse osmosis) water minimizes mineral residues. If you do use a prepared cleaner, make sure it is safe for both electronics and plastics.
4. Always moisten the cloth. Never spray an aerosol directly onto your printer.
Cleaning a Laser Printer
1. Turn the printer off, unplug it, and allow it to cool down before you begin.
2. Remove the internal paper trays.
3. Remove the toner cartridge and place it on a piece of clean paper.
4. Clean inside the toner cavity with a dry, lint-free cloth and printer brush.
5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided.
6. Wipe away dust and spilled toner. Remove paper fragments.
7. Clean the rollers, but don’t touch the transfer (sponge) roller.
8. Replace the toner cartridge.
Tip: Exposure to light can damage toner cartridges. Always cover your toner cartridge with an extra lint-free cloth or piece of paper after removing it.
Cleaning an Inkjet Printer
Most inkjets have a self-cleaning process you can access from your printer’s control panel. If that process doesn’t remedy the problem, try one of the following. Remember to check your manufacturer’s documentation and the product documentation to be sure it is right for your printer.
1. Inkjet cleaning cartridges flush dirt and debris out of clogged printer nozzles, restoring the quality of your prints and prolonging the life of your print heads. However, take care that the cleaning fluid you use is approved for your brand and model of printer.
2. Before cleaning inside your inkjet, turn it off and unplug it. Let it cool down if necessary.
3. Dust, hair, and lint from inexpensive papers can gum up your printer’s rollers. A computer vacuum is usually a safe way to remove debris.
4. Roller cleaning sheets can help in cleaning print rollers. Again, check documentation before use.
Tip: Most manufacturers recommend against using compressed air since the propellant may add moisture to the inside of your printer.
Mar 29, 2010 | Brother DCP 165C Compact Color Inkjet...
Printer keeps stopping halfway though run of labels. Red light comes on and when pressed goes green reprints last label then a few more then stops again.
Usually this is a sensor problem. The printer is not recognizing that the labels are moving through. Remove the labels and blow out the interior with clean air. That may resolve the problem. Dust can accumulate on the sensors and cause this.
Please update this if that does not resolve the problem.
Thanks,
Dan
Nov 04, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Laserjet 4MP paper jam problem Half feeds from
I have seen this issue before and your problem is likely due to very fine paper dust on the pickup rollers. This is easy to fix and takes only a few minutes. Use a soft piece of cloth (not a paper towel), a computer cleaning towelette or anything that does not produce lint; dampen it (unless your are using a towelette) slightly with cleaning alcohol and wipe off the paper pickup roller on all sides. You should also remove the toner cartridge and vacuum out the interior of your 4MP, use care if you are not used to poking around the interior of HP printers. You will usually find both white paper dust and maybe some black toner dust. Put the cartridge and paper tray back in place, print a couple of blank sheets as a test - you should be good to go.
Oct 03, 2009 | Office Equipment & Supplies
A loud buzzing is coming from our blower- the piece I indentified as the Contactor. What does this mean? Do I need to fix and about how much should this cost?
This can be one of those jobs that fall under 'while I'm in there, I might as well do some spring cleaning and investigating'.
The noise that you're hearing could be a couple different issues ranging from safe to dangerous:
- something has been dropped into the 'squirrel cage' (fan), causing the noise as the motor turns the blower fan. Typically, if you have children, it's not hard to end up with a lego, piece of construction paper or other item being tossed into the blower. A playing card can end up sounding like a 'buzz' when lodged within the blower housing as the fan is turning at high RPMs.
- the contacts, as you've identified as the possible, may not be making a complete connection anymore, causing an electrical arc that subsequently can cause damage to the motor itself by limiting amps to the motor and FIRE with the presence of dust or other flammable debris.
To be on the safe side, cut power to the unit by flipping the breaker that it operates on at your breaker box (OFF), remove the blower by removing a few bolts and have it completely blown out of all dust and debris with an air compressor. This will lower the risk of malfunction, fire and costly replacement of motor later on. At this time, check the motor... specifically the copper coils and leads... for scorching and the internal brushes (contacts) for excessive wear.
Check all connections for singed areas, tell-tail burn marks that suggest arcing, surging or the presence of moisture within the unit. If anything related to the electrical system (wiring, contacts, connectors) appear to be worn or damaged, it would be best to hire an electrician to repair/replace what is necessary to ensure the safety and continued efficiency of the unit... and to get that valuable labor warranty if similar problems develop later.
As for pricing: it's very hard to say, considering we're not sure what type of unit we're referring to. If this is an internal home heating/cooling unit, most of the internal components are available for little cost at Lowes, Home Depot or any other home improvement warehouse or are able to be directly ordered from the manufacturer of the unit if the unit is not ancient (over 20 years old).
Good luck and be safe.
Jul 07, 2009 | Goodman CKL42AR42 Air Conditioner
Internal cleaning
Note:
Not all printers are the same
Would be usefull to know make and model
and where "dust" is; as to whether it can be cleaned "DIY" way
Jul 03, 2009 | Office Equipment & Supplies
Brother HL 1440 Laser Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
