Question about Honeywell HZ315 QuickHeat Ceramic Compact Heater
Honeywell HZ315C ceramic heater turns on and heats well. After a minute or so it clicks off. Unfortunately it does not turn back on. Power light remains on. If I unplug the heater,wait twenty minutes, heater works again but same problem occurs. Only two years into five year warranty. No service centers in Canada so you have to mail it back in at your expense. Could this be the thermostat and can thermostat be jumped. Would then run it at five minute intervals on timer and only when I am sitting next to it. Thanks.
    Genius:
  • 1,015 Answers
Yes it could be the thermostat and you should be able to bypass it.If you do this you will want to monitor it closely as you're thinking for safe operation. Thank you
Posted on Mar 28, 2011
Honeywell portable heater HCE322V manual
Honeywell has the manual for the HCE322V ceramic tower heater on the product page: http://www.honeywellstore.com/store/products/digital-ceramic-tower-heater-hce322v.htm . Click on the Manuals tab. The direct link to the manual is http://www.honeywellstore.com/store/images/pdf/HCE311-HCE322-HCE323-honeywell-heater-manual.pdf .
I hope this helps. Note: the manual covers a few different models. You should ignore any section about the HCE323; that model has a remote and a few other extras.
Jan 08, 2017 | Honeywell Heating & Cooling
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Heater turns itself off after 2 minutes.
there might be timer setting or there coil is faulty.check it.
Jan 14, 2009 | Honeywell HZ-3220BW Compact Heater
Thermostat
I have seen some thermostats that have a ceramic stem attached to the inside end of the control shaft. The ceramic stem is non-conductive and heat-resistant. If this stem is broken or missing, then turning the knob will have little or no effect.
The solution is to replace the thermostat.
Feb 21, 2008 | Honeywell HZ2110 Utility Heater
My honeywell heater was working one minute and not working the next.
HI I have this heater and no manual , and I was doing research on the internet and found that these haeters have an automatic shut off if it gets too hot and it wont come back on for a while until it is cooled down. I just unplug mine awhile or turn it off and then it comes back on when it cools down.
Jan 02, 2008 | Honeywell HZ335 Ceramic Compact Heater
Honeywell ceramic heater hz341bl
Like most heaters, this Honeywell ceramic heater has a tip switch designed to turn the heater off if it falls over. Unfortunately, all you need to do is bump the heater and the switch can open. Sometimes the switch will stick and the heater won't come on even when it is upright—sticking during storage could easily happen, particularly if not stored upright. When the switch is stuck on my heater, when I try to tturn it on the yellow and green pilot lamps flash once but nothing happens.
The solution is to rattle it, shake it, and invert it a few times to unsitck the switch. It always works for me. Something probably best done before you get frustrated to the point of shoving it through the floor. Also, if the heater was running when the switch sticks, be sure it cools down so the thermal switch has a chance to come back on.
Nov 23, 2007 | Honeywell (HZ-341BL) Ceramic Heater
Honeywell hz-341-bl ceramic heater
take a heat gun or a blow dryer and preheat thermostat and any conductive leads.
after a few pre-heats it will get the idea!
Nov 15, 2007 | Honeywell (HZ-341BL) Ceramic Heater
Honeywell HZ315 QuickHeat Ceramic Compact Heater Logo
133 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
