Question about OKI B4600 Printer
Hi, my oki b4600, is showing err231 3F, after i changed toner cartridge, tried to unplug it and plugged it back, but did not solve problem. need help please. Thanks mike
5 Suggested Answers
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
  • 97 Answers
SOURCE: oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Posted on Mar 29, 2010
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
  • 97 Answers
SOURCE: OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Why is it putting black blotches of ink all over the paper?
You might have a leaking drum. Or toner might have spilled in the printer during a cartridge change. if you have a HEPA Vacuum with a soft bristle brush lightly vacuum any spilled toner in the printer and try again.
Apr 14, 2015 | OKI B4600 Printer
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
Change drum? german
The internal counter has reached the maximum number of prints that is expected from the drum unit (the green cylinder to which you attached the toner cartridge too.) so it requires changing for a new one.
May 10, 2011 | OKI B4600 Printer
We have an Oki B4600 Laser Printer. It is about 6 months old and has started printing vertical white lines through our pages. It originally came with a toner that was half full (I was told) so we quickly...
This is a simple and common problem with many LED print head printers. You just have toner dust on the surface of the print head. Run your finger along the head and all will be well.
Jun 16, 2017 | OKI B4600 Laser Printer
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Aug 07, 2009 | OKI B4600n Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Oki b4600 drum reset ?
Jun 19, 2009 | OKI B4600 Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
OKI B4600 Printer Logo
835 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
