Question about Nokia N95 Cellular Phone
N95 not powering up
Did you find a solution ti this ? I have the same problem.
Thank you for sharing it with me.
Best regards,
Lars
I sent the phone off to get fixed at a local menders. The problem was too serious for them to fox and they sent it off direct to Nokia. Within 10 days I got a completely new phone back, the problem could not be fixed. If your phone is covered under warranty, you will get a new replacement phone.
Posted on Aug 06, 2008
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
Hey there I need a driver for Haicom HI203E driver windows 7 where can I find it Best regards Lars Mikkelsen
Head on over to Haicom:
http://www.haicom.com.tw/support.aspx
They've a link for Windows 7 drivers for USB connection to the GPS.
Best of luck!William
Mar 03, 2011 | Computers & Internet
Have wrtten a question but why should I be stupid to pay for a simple answer. Forget it!!!! A simpel question should be a free service!! Lars Nyman
Hi, Lars, W/D here.
Sorry that this appeared offensive to you. Take another look!
When you come to FixYa, you have several options. The first is to post your question and people familiar with your issue give you repair options for free. If you don't want to wait, and wish to go directly to one-on-one chatting for a fee, you can do that too.
You don't have to pay anything to post a question here, and you'll get a good many answers from experienced people who are just trying to help people like yourself repair the things that they can fix without the cost of a service call. Pretty good deal, huh? Anyway, you've misunderstood how this works. Give it another try, and I think that not only will you be back, but you may find yourself willing to help others by sharing the things that you know how to do. Great Karma.
Best regards,
--W/D--
Jan 22, 2011 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
My nokia n95 pin code block and asking puk code? how i can get puk code regard RAD
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Aug 20, 2010 | Nokia N95 Cellular Phone
DFI ns35-tc/tl Total power off requested. When pc is turned off,a red led light keeps shining, indicating motherboard is still powered. This is probably the reason that a USB Power Saving Center will not...
The red light is just a pilot light indicating that it is still
connected to the power line. To get it totally off, is to
unplug the unit from the outlet. If your PC is connected
to the AVR (Automatic Voltage Regulator), just turn the
power switch off at the AVR. Hope this help you.
Dec 09, 2009 | DFI NS35-TL Motherboard
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Restore factory setting fake n95
Hi Friend,
Can u try below mention code,check it out and revert back
00000000
regards,
Ayyasam
Jun 25, 2009 | Nokia N95 Cellular Phone
Where can i get USB cable and charger for WQ N95 ?
first you should try finding it on ebay or criags list(they have the best deals)... if that doesent work then try speacial ordering from the makers website ex. garmin or tomtom
Sep 10, 2008 | GPS
Nokia N95 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
