Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi projection tv
I have a 2001 55 inch Mitz projection tv. I havent had any problems with it until this past weekend. When you try to turn on the power to the tv, the green light will come on for about a second then it will turn off. The power will not stay on. What do you thinkt he problem is, and how much does it cost to repair the problem?
    Genius:
  • 2,920 Answers
Power supply and it will cost 3 to 400 to repair
Posted on Aug 25, 2008
Why when u replace lamp in MITZ TV do they emit this smell that makes me sick to my stomach. its been 5 wks and it still stinks?
Did you replace the lamp with a Mitsubishi exact replacement? If so, take the lamp back out and see if you accidently left the silica gel packet in the lamp cartridge.
Aug 24, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 bglod fixed, but inputs are broken
look for dried out thermal paste on the transistors / i.c.'s especially on the power supply board.
test while the set is on, carefully! using coolant spray (freon) and, a hairdryer to find heat related faults keep turning the set on and, off to replicate the problem as you heat and cool components until you find the offending component. the coolant is non-conductive and, will not harm anything it touches except you. wear safety glasses and, keep your hands out of the way of the spray nozzle.
remove old non-conducting paste if a component gets too hot and, re-apply the paste.
radio shack sells the coolant spray (component cooler) and, the paste.
Jul 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Turns off
hi
check the power button is not jamed) stuck
Jun 09, 2010 | Mitsubishi WS-48311 48" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Turns on then off
CK for open fuses and Bad capacitors
Jan 23, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
Dec 13, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Problem with Projection TV
This set is very common for the str typr power regulator to go out on it. Its not a consumer replaceable part. Please find a trained tech to assist you with this repair. Good Luck
Aug 09, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
