Question about Intermec CN50 Handheld Mobile Computer - P/N CN50AQU1LP00 Portable Terminal
How do you find the IMEI number within the CN50? We know you can find it behind the battery but would lilke to see how to find it when the phone is on and within the settings. julie.thede@airclic.com
Need to disassemble CN50 to retrieve SIM card
hi
Page 60 has the answer, it may be very stiff, gently tug it with some small pliers.
http://www.milesdata.com/documents/INTERMEC/CN50/-intermec-cn50-user-manual.pdf
Mar 06, 2013 | Intermec CN50 Handheld Mobile Computer...
When device is getting on device is hanging in windows mobile version screen
If its not booting up correctly you can either clean boot the device or reflash the firmware. Note this will return trh device to its default state and loose any information stored on the device.
Clean Booting the CN50
If the CN50 seems to be locked up, try warm booting and then cold booting the computer. If neither method works, use a clean boot to get the computer up and running for further troubleshooting. When you clean boot, the CN50 only loads files and applications that are absolutely required by the operating system. A clean boot returns the CN50 to an "out of the box" or factory default state, so that you can run diagnostic tests to troubleshoot the normal boot processes:
To clean boot the computer using the mobile computer:
1 Remove the battery pack from the back of the CN50.
2 Reinsert the battery pack and press the Power button.
3 When the CN50 starts the boot process, simultaneously press <and > until the IPL Boot Configuration Menu appears on the screen.
4 Press 2 to select Force Clean Boot and then press 0 to select
Continue with Boot.
The CN50 executes the clean boot. This process takes a few minutes
The clean boot process erases the CN50 memory, including all applications and data files in the object store. To preserve applications through a clean boot, store them in the Flash File Store.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 15, 2012 | Intermec CN50 Handheld Mobile Computer -...
Where is the IMEI number on sanyo scp 5500? I want to unlock it, but they ask fo a IMEI number that is 15-17 numbers long. All I can see is ESN DEC and 11 numbers after that. And below that is a ESN HEX...
IMEI is short for International Mobile Equipment Identity and is a unique number given to every single mobile phone,
Its -typically found behind the battery..
"How to Find the IMEIof Your Cell Phone?
Method-1
Press *#06# on your cell phone. The IMEI number will appear.
Method-2
Remove the Battery of the Phone and Look at the sticker below the battery on your mobile phone IMEI should be there.
Method-3
Go to the setting manu,choose ""about phone"" option,IMEI should be there"
To unlock any brand phone just go to
Unlock Your Cellphone Use Any Network in The World
Feb 06, 2018 | Sanyo SCP-5500 (VM4500)
My imie number was two numbers off when i dialed the*# number the imei number behind battery did not show the two other numbers
The IMEI number is uniquethe each mobile phone. The number is printed onthe label under the battery. You can also get theIMEI number by entering this on your phone *#06# It will then display your IMEI numberand you may also get a unique global serial number. Your IMEI number should be15 digits.
Jun 15, 2011 | Cell Phones
I forget my keypad lock password of 6600 nokia.i dont know even its serial no but it has my vital information which i dont want to delete.
can you tell me your phone imei so i can send you the master code??
your imei are located behind your battery on the cover of your phone, just release your battery then you'll see the barcode sticker where your imei number located
May 15, 2011 | Nokia 6600
Im trying to get a .cer app for this phone but I tried all the numbers behind the battery and they dont aork as IMEI where can I find it?
Mar 10, 2011 | Cell Phones
Forgot my nokia n95 lock code
You can get into your Nokia N95 by getting the IMEI number, you can get the imei number by taking out your battery and looking behind the cell phone or alternatively you can dial *#06#. We can only use the imei number to unlcok your phone. Since you can't get into the phone then that's not an option, hence stick to option 1 where you have to take out the battery and look behind the phone for the imei number.
Get the imei number and post it here, then i'll generate the security code for you to unlock your mobile.
Regards
Nov 02, 2009 | Nokia N95 Cellular Phone
How can i get into my nokia 5310 since i lost my code?
You can get into your Nokia 5310 by getting the IMEI number, you can get the imei number by taking out your battery and looking behind the cell phone or alternatively you can dial *#06#. Since you can't get into the phone then that's not an option, hence stick to option 1 where you have to take out the battery and look behind the phone for the imei number.
Regards
Oct 18, 2009 | Nokia Cell Phones
Can i have the code to unlock the samsung t629
Hai,
U go this site mobileunlocker.In that that Go to Unlocking service and click Samsung unlock service.U will buy the unlockcode for this.u will get the unlocking instructions for Your mobile phone.
Jan 07, 2009 | Cell Phones
Phone restricted
Give me your IMEI number and the network that was locked to and i'll send you unlock codes.
The IMEI number is behind the battery a 15 digit number.
Feb 14, 2008 | Cell Phones
Intermec CN50 Handheld Mobile Computer - P/N CN50AQU1LP00 Portable Terminal Logo
236 people viewed this question
Top Intermec Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Tom Chichester
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
