Question about Western Digital My Book Essential Edition 2.0 1 TB USB Hard Drive
I have a WD external driver for my PC. It is an old version about 2006. I connect it with my computer, there is a blue light that means it is connected(kinda reads it) but it doesn;t show the driver anywhere in the screen. I tested other cables (2 USB entrances/big-small) It used to work before with the small usb2.0 cable(for the netbooks) I don't have access to my files and it seems that i cant use the disk. I also tried opening it but it needs some extra tools for the inside. Contact me because I don't want to lose certain documents and it was very useful for transfering and storing files. Thank very much!
    Guru:
  • 433 Answers
Dear listen to hd when it work if you hear a low tike that is mean its damaged
if no tik do that write click on my computer - manage - disk manaement see your hd if itsn't appear that need a mantinance engneer
best regardes
if you see that is helpefull plz vote me
Posted on Mar 28, 2011
I forgot my password to get to my files on my external WD hard drive 1 To.
Posted on Jul 17, 2011
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
Wd External HDD 1Tb Essential Edition clicking sound
Go to device manager and uninstall all usb drivers then restart computer .
if still problem remains same then check your usb external harddisk to another computer.
If in other computer same problem then your harddisk need repairing it has hardware issue.
Aug 01, 2009 | Computers & Internet
How to recover WD passport250 Data
hi...if you want to see again the files on the external hard drive i suggest you make to re-install the windows or repairs the windows you`re using or try to update the mother board drivers..thank you...^_^
May 09, 2009 | Computers & Internet
Hd only switches on briefly the shuts it's self down
If it has another connector type ie firewire or usb ( the opposite of what you are using ) then try that.
If its usb then you can go into device manager and un install the usb hub under usb devices etc and re install your motherboard drivers and re connect the hard drive also if you have a laptop or a friends computer you can connect it to temporarily to install it on just to see if it works on there computer - if it does then that means the hard drive is fine if not then it points at the hard drive.
May 09, 2009 | Western Digital Elements powered by WD 320...
WD my book 320gb not responding
don't panic your hard drive might still be working . you say it dose not sign showing it's on. please have any cable that connect the hard disk to the computer checked. I think your cables might be bad.
thanks
Nov 20, 2008 | Western Digital 320GB MyBook External USB...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
I recently purchased a Dell XPS 420 Desktop computer, running Vista, from Dell, including a WD 500GB MyBook external hard drive. The power button did not function from the get-go, but I was able to copy...
Unfortunately if there is no driver for Vista, then your out of luck. Since Vista is a widely used OS and getting bigger, then the MyBook manufactures must create a Vista driver soon or they will be in danger of going out of business. Just wait and periodically check the MyBook website for new drivers.
Feb 11, 2008 | Computers & Internet
Western Digital My Book Essential Edition 2.0 1 TB USB Hard Drive Logo
250 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
