Question about NetGear WG602 802.11g/b Wireless Access Point
Hello, I have Netgear WG602 V4 access point. now I am facing a problem loging in the product which it will not allow me to get in . I tryed so many times by typing the IP ( 192.168.0.227) but without use. could you please help me by showing me how to loginto the product. thanking you
  • 85 Answers
I believe you are using the wrong IP. Try 192.168.0.1 instead. The way you can confirm is go to start>run type in "ipconfig" and press enter. Look for your gateway ipaddress. This is most commonly the IP you need to use to login to the router.
Posted on Mar 28, 2011
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
NETGEAR AND UPNP
Yes your Router supports UpnP.
http://kbserver.netgear.com/pdf/wg602v3_manual.pdf
Here is the manual where I found the information. Once the manual is open ctrl+F will open a find window. In the find window enter UPnP and click enter on your keyboard. This will take you to the section explaining UPnp and how it works on your router.
Good Luck!!
Aug 13, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't configure netgear access point wg602
try to access the the router by using address 192.168.1.1, if this don't work then reset the router and used the factory setting in the manual
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
How can I configure a netgear wireless access point to talk to my wireless dlink router?
What do you mean by talk? Are you trying to bounce the wireless signal for a greater range?
Nov 21, 2009 | NetGear WG602 802.11g/b Wireless Access...
Power light on - the rest off
It has happened to me on a couple of occassions. Call your Internet Service Provider, sometimes you lose the connection because of something on their end. If they are any good they will walk you thru some troubleshooting steps to verify if its on their end or yours and set you up an work ticket to fix. If you have any questions let me know. Pls rate this solution.
Apr 30, 2009 | NetGear WG602 802.11g/b Wireless Access...
Wireless light does not light
Hey Nassim, ;
Please note that the concerned product is a wireless access point and not a wireless adapter.
For drama_que916
Please reset the Access point by pressing the reset hole on the back panel of the AP when it is being powered on. after 30 seconds release the rese hole and then turn it off and then turn it back on
Now check if it shows proper lights.
Mar 17, 2009 | NetGear WG602 54Mbps Wireless G Access...
Netgear wg602
The advertised power output of a NetGear WG602 is 16dbm, using an online converter, that would be 39.81 milliwatts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 22, 2008 | NetGear WG602 802.11g/b Wireless Access...
How to Configyre a wirless adapter
If this is a wireless adapter just install the driver, on the PC (the disk that came with the adapter) then plug it into the PC and connect to the wireless router.
Hope that helped.
Oct 18, 2007 | NetGear WG602 54Mbps Wireless G Access...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
NetGear WG602 802.11g/b Wireless Access Point Logo
276 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
