When i start up my hp desktop, it just comes up to a blue screen, which gives 4 options. Here are the options: 1. esc-boot 2.f10-Recovery 3.f11-system restore 4.f5-options However when I press any one of these, they do not seem to respond at all.
  • 63 Answers
This problem is troubling. It seems that your hard drive might have failed. (Since there aren't many details about what is going on, there could be other explanations as well.) If it is in fact a hardware failure then your option would be to purchase a new hard drive, but that would mean losing all of your data. The other solution is that there is something going on with software - which would be a better problem.
One last thought, make sure there isn't a function button on your keyboard that is pressed which would change the function keys to hotkeys with alternative functions. Best Wishes!
Posted on Mar 28, 2011
    Scholar:
  • 45 Answers
Do you still have your setup disc in the drive? It sounds like your BIOS is trying to boot from the disc instead of the hard drive. Try removing any discs that are in the drives before the boot. If this doesn't work, you may have to change the bios to boot off of the C: partition. I know that HP pc's sometimes build in a secondary partition which is usable as a "system restore/recovery" area, and when they try to boot from this secondary partition, it can cause these types of issues.
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
But my laptop even don't work in safe mode. Blue screen appears and computer restarts again . What to do??
Try running the last known good configuration.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Jan 06, 2011 | HP Compaq nx7010 Notebook
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
My comp in not stating, showing blue dead screen,
Use your restore disk, or if you have a Windows OS disk, bootup with that.
When you see the screen that gives you an option to "Repair Windows" hit the "R" key. You will be taken to a DOS prompt. Choose the Volume you want to repair (Usually number 1) then it will prompt you for an Administrator password. If you have never put one on the system, simply hit Enter. The it will take you to "C:\Windows" Type in the following...
"CHKDSK /R" (without the quote marks and hit Enter. Let chkdsk utility see if it can repair the volume. It will prompt you when it is finished.
Apr 25, 2010 | HP Pavilion m7490n PC Desktop
My computer has lost all sound. I have no clue how to get it back. There is non on the control panel
u will need to reinstall your audio driver u can get this from your computer Mfg web site under support driver downloads. or you can try to rollback the driver from the device manager menu "Start right click computer select properties select hardware then device manager then select sound and video controller find you audio driver and double click and select roll back if this does not work refer to the first step reinstall driver from mfg website hope this helps
Oct 11, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I NEED TO FORMAT MY PC TO START NEW
okay its esay follow me!!
1/insert cd of win Xp SP2 Recomanded
2/when it say press any key to boot from cd /press andy key/
3/after the blue screen gives options press enter
4/select c:
5/format it using fat32
6/let it continue till the end..
Aug 25, 2008 | Gateway Computers & Internet
Computers & Internet Logo
David Payne
David Payne
