I followed info on line and got an error code 61 - however I can't find out what error 61 is. My washer seems to be working ok - I have done several loads of laundry - but it keeps beeping and beeping! It's driving us crazy. We unplug it when not in use, just so we don't have to hear the beeping. My washer is only a few years old. Can you help? It even beeps and lights flash during a load of wash.
    Brigadier General:
  • 6,277 Answers
Sorry, you do not say the make and model of your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 28, 2011
How to fix the following trouble message please thank you beforehand
This info is for technicians and explanations for the codes is limited to them
Jun 23, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Is there vacuum line to winshield washer?
Carlos, No vacuum line to washers, the rubber hoses look just like a lot of vacuum lines and could be mistaken.
error code P0155 is Heated Oxygen Sensor fault, Heater Circuit Bank 2 Sensor 1.
Around 98% of the time, you can assume correctly,without any specific testing, that a new O2 sensor is in order and will solve the problem.
press the helpful button and follow me on fixya for more tips and info.
How to Replace Oxygen O2 Sensors On Your Car
http://www.obd-codes.com/p0150
What that Service Engine Soon or Check engine scary light means DTC Error...
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0ahUKEwjCosyAlu7KAhXHuIMKHenFCsUQFghFMAc&url=https%3A%2F%2Fedgeproducts.com%2Fapp%2Fuploads%2F2014%2F08%2Fcustomer_support_article-pdf-40.pdf&usg=AFQjCNEbFVrArJmnvWcb7a1_mrT1Q_DcZQ
Feb 10, 2016 | 2004 Buick Regal
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
How do I reset all codes?
I don't know what kind of washer you have but fault codes usually indicate that something is wrong. You don't just reset them.
You might find some help here but you will have to change the search terms.
washer error code YouTube
If you have your model number you may find help at sears parts direct.
http://www.searspartsdirect.com/
Nov 07, 2014 | Washing Machines
Flashing code F71 then F70
We've owned a Whirlpool Duet Washer (WFW9200SQ00) for about 3 years. We started getting the F70 error code intermittently about 6 months ago and it seems to progressively be getting worse. Unplugging the unit for a few minutes resets the error, but it comes back about every 2nd or 3rd load causing my wife a lot of frustration and with 4 kids, our laundry was backing up. After reading several Forum's, I found the F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board. Before spending nearly $250 for a replacement board (http://www.helpfulparts.com/servlet/the-5733/8183196/Detail) with no guarantee that it would fix the problem, I decided to take the board out of the machine and inspect it. What I found is the connector for the communication (the connector with three blue wires) on this board is a very unreliable connector that uses the edge of the printed circuit board on one side of the connection instead of a real connector soldered to the board. In addition, the fit of this connector seems to loose to make a good connection. I noticed a little bit of corrosion on the board contacts which I cleaned with rubbing alcohol and a pencil eraser. After re-installing the cleaned board we've done several loads with (keeping my fingers crossed) no errors. I am still concerned about the reliability of this connection. Because of it's location, this board is subject to a fair amount of vibration and because of the loose fit I'm concerned that this issue will only come back over time. I've already decided that if the error comes back I will solder wires to the contacts on the board to provide a more robust connection. It's a shame that you can spend well over $1,000 on a top of the line washer, and in order to save $.10 Whirlpool decided to use a very poor connector in a critical area. It makes you wonder where else did they skimp to save a few pennies?!! Our next washer will not be a Whirlpool, and next time will not get a high end washer with all the bells and whistles.
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Elite HE 3t
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
Weird lines moving on an 1st gen itouch
Hey,
follow this guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
in the end theres the warranty info checker, you may need to send this one to repair, check your warranty with the tool ones your done. Its the last thing on the guide.
Thanks,
Ekse
Feb 15, 2009 | Apple iPod touch
My whirlpool Duet Washer is displaying a F70 error code, how do i fix it
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
