Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
HI, AFTER REPLACEING PLASTIC GEARS IN SAERS GARAGE DOOR O[ENER, OPENER WILL NOT GO THROUGH COMPLETE CYCLE. WHEN BUTTON PUSHED TO OPEN, OPENER GOES INTO CLOSE CYCLE AND HITS STOP BOLT. ATTEMPTED TO ADJUST LIMITS AND FORCE WITH NO SUCCESS
    President:
  • 3,197 Answers
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Posted on Mar 28, 2011
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
My gear driven garage door opener is making a loud noise
I did garage doors for 20 years and I am going to say it's not the plastic
pinion gear but the 7" three piece metal screw in the center of the rail that goes from the head unit to the wall just above the top of the door that needs lubricated. It spins inside metal to metal and will make a heck of a racket if it is dry. Buy a spray can of lithium grease and disengage the garage door and start the opener and spray the complete screw front wall to the head unit and your done.
Reconnect your garage door and give that a try, I bet that solves your
problems.
Do this every couple of years. :0)
Jun 09, 2014 | Genie Company Genie 27092A Replacement...
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Why wont the replaced liftmaster sprocket turn clockwise after replacement?
Looking down at the sprocket. When it turns clockwise it is closing the door and when it turns counterclockwise it will be opening the door.
Jul 01, 2012 | Sears Craftsman LiftMaster Chamberlain...
It's not a remote part that I replaced it's the plastic gear of the garage door on the ceiling of my garage. Now it does not work. Only goes up and down 2 feet when I press the wall button in my gara
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Nov 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Our garage door will not open all the way. Up until yesterday it worked fine. Then when I came home from work and pushed the button to open the door, the door raised up about 3 inches and stopped. I pushed...
You have either a broken door spring or the drive gear in the motor unit is bad. The drive gear is a white nylon gear just in front of the motor and it will be obvious if it is bad.
Nov 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door goes up about a foot and stops
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener goes 12"+/- and then returns
havent heard any of yu say you adjusted the down force.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
129 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
