Question about GE JVM1653 Microwave Oven
Microwave simply stopped working. Initially thought it was the fuse. When I opened the casing, I saw that the cord had burned-off at the contact point in the images. Fuse is still good. The unit is location (over the oven) is dry as a bone. No other rust, corrosion. My question: Should I replace the cord and that plastic adapter or is there a place I can go to simply replace the plastic male adapter fitting? [IMG]http://img846.imageshack.us/img846/3016/microwavecord03.jpg[/IMG] By [URL=http://profile.imageshack.us/user/amalgamofimages]amalgamofimages[/URL] at 2011-03-28 [IMG]http://img15.imageshack.us/img15/8416/microwavecord02.jpg[/IMG] By [URL=http://profile.imageshack.us/user/amalgamofimages]amalgamofimages[/URL] at 2011-03-28 [IMG]http://img535.imageshack.us/img535/8600/microwavecord01.jpg[/IMG] By [URL=http://profile.imageshack.us/user/amalgamofimages]amalgamofimages[/URL] at 2011-03-28
  • Johnny Mar 28, 2011
    Male electrical adapter/fitting
  • 675 Answers
You can obtain ge components from mcmelectronics.com.....they are a GE parts supplier...if they don't have it...then try www.ued.com.....by the way... I would change the whole assy.
Posted on Mar 28, 2011
Testimonial: "Thanx for the links. However with shipping the fees, a simple Molex connector was almost $20. I ended up wire nutting the connection."
Whirlpool ukm120 microwave stopped working
1) you use contacts cleaner with very speed dry or isopropyl alochol to 100% for dry the humidity sector inside from microwave.+power cord+main switch. The reason is has humidity. This water or some other liquid are NOT conductors.by that reason isolated. See if some parts are burned or smell strange.
2) test the fuse again. 3) dry the HV transformer and magnetron with infrared LAMPS by 8-10 hours for to dry any humidity.
3) and try again.see the inside of microwave
Jul 26, 2012 | Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
LG Microwave ran empty for 20 minutes
I recommend you have a service man come in because it is more than a fuse, the keypad control board will need to be checked along with the rest of the system.
Apr 22, 2012 | LG Microwave Ovens
KitchenAid KCM2145JSS-1 built-in Doesn't Heat
Everything working is a real good sign. Most likely all thats wrong with your unit is a blown fuse. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=kcms145j&SearchTerm=fuse&RefineSearch=0 and you will find the fuse. It's behind the touch pad with most all the other workings. Very easy to replace and cost only $11.76. It looks like an old round glass car fuse but it's made just for micro waves. It's most likely a 20 amp fuse. To get to it, take all the screws out from the back that hols the case on. once you have removed the case you will be able to locate the fuse. Good luck.
Dec 19, 2009 | KitchenAid KCMS145J Microwave Oven
We have an emerson microwave oven mw8119sb mnfd sept 08. It stopped working - couldn't get anything to show there was any power. Opened it up & found a burned wire (brown) coming from little power...
I had this exact issue. I purchased this used from someone and thought I got jipped. I opened it up because I have a bit of electronics experience and saw the brown wire. The schematic says that its a thermal cutout. Basically a fuse. I just soldered them together. Might be bad in the long run (fire hazard) but it works and doesnt get hot. The reason the paper clip trick didnt work for you was because thats way too much current through a small piece of metal. Try something with more volume
Dec 08, 2009 | Emerson Microwave Ovens
Why wont it power on?
probably a burned out fuse.
unplug it, open the case, and trace the power cord. There is usually an in-line fuse before the cord attaches to the main transformer.
buy a replacement in the hardware store, look for an old-style automotive fuse.
Oct 20, 2009 | Emerson MW8985W Microwave Oven
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
Purchased microwave oven model #wes1384smss on 1/31/08. Since purchasing, oven periodically simply stops functioning (microwave), but lights are on. After about 5-20 minutes, it will start working again...
Since it's still under warranty, I would contact GE Customer Service here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Microwave Ovens
GE JVM1440 Spacesaver Microwave
You can fix it without the aid of a repairman. Simply unplug the microwave and remove the outer casing. There should be a few screws around the bottom edge and back panel. Once you have the unit open, look for where the power cord comes in. There should be a circuit board with a fuse mounted to it. This is your input line filter. The fuse should be a 20 amp appliance fuse that you can pick up at any hardware store (Lowe's and Home Depot both carry them). DO NOT op test with the outer casing removed. Potentials of about 14,000 volts are present in the high voltage network of a microwave oven. Close the unit up BEFORE you power it back up. Let me know if this helps.
Aug 11, 2007 | GE JVM1440 Microwave Oven
GE JVM1653 Microwave Oven Logo
276 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
