Question about Cameras
When i turn on the camera lens automatically comes out but goes straight back in again. New batteries inserted but sti the same
  • 66 Answers
It's possible there is some obstruction blocking the lens. Check around the lens and see if there is anything small like a piece of cloth, or anything that could get stuck when retracting.
Posted on Mar 28, 2011
  • 164 Answers
That's an internal problem, not related to batteries. You have to take it to a repair shop to have it checked out.
Camera comes on then right back off new batteries
I had this problem with a Canon that was about 4 years old. After some hunting, I found out that a main control in the camera was broken or worn out. The cost to repair was more than a new camera. Before you give up on it tough, try a new card. I have read that an old or corrupted card will cause cameras to act screwy.
May 07, 2014 | Polaroid Cameras
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Aug 13, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Flashing yellow light -- lens won't retract
Lens is jammed, you need to get it back on track. Gently push lens back in with a flat object to keep it straight, like a tabletop while powering it on. This may or may not work, but a jammed lens on these styles of cameras is common and renders the camera useless.
Dec 07, 2008 | Canon PowerShot A80 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Kodak V530
Same problem, have an M883 although this seems to be an issue with older models as well.  Something defective I am assuming.  I have taken proper care of my camera (storing it in the case, ensuring no liquid touches it, etc.) I plan to call them in the morning.
Apr 17, 2008 | Kodak EasyShare V530 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Kodak easyshare v530
Kodak easyshare V530 camera turns on then straight back off again bought a new battery but still does the same. Lens goes out a bit but then straight back again.
Feb 20, 2008 | Kodak EasyShare V530 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
