Question about HP Mini 1000 Netbook
Hard disk making funny noise and netbook does not recognise boot device after automatic windows update and restart.
    Scholar:
  • 58 Answers
You either have an error with your hard disk or with the Windows partition files.
Some HP Mini Netbooks have a hard drive self-test feature. In order to check for a hard drive problem, turn on your computer and press the "F10" key during startup. This will open the Setup Utility. Use the arrow keys to navigate to the "Diagnostics" menu, then highlight "Hard Disk Self Test". Let the test run fully. If it reports an error(s), then you have a damaged/defective hard drive, and you will need to replace it by either contacting HP through their support site, or by replacing the drive yourself with a new one.
If the Setup Utility cannot detect your hard drive at all, then you either have a defective hard drive /or/ a defective SATA controller (this is what connects your hard drive to the computer). Unless you can connect your hard drive to another computer, it is very hard to determine which is causing the problem. You should contact HP if you are under warranty, or check in at a local computer repair shop if you are not.
If there are no errors reported with your hard drive, then either your hard drive only fails some of the time (and you should be able to boot into Windows at the moment), or there is a problem with the partition (section) on your hard drive that handles booting up. You will need to reformat the hard drive and reinstall Windows in this case.
Posted on Mar 28, 2011
`no bootable device insert disk and press any keys what should i do
Have you left a CD in the CD Drive, if so take it out and re-boot.
Can you access the BIOS - if so check the Boot Order and ensure the Hard Disk is the first boot device.
Also check that the BIOS is recognising the Hard Disk.
It maybe that the Hard Disk has gone down - can you hear it spinning up or down when you boot up or switch off. Make sure it is seated correctly.
Aug 22, 2012 | Acer eMachines 350-2074 Netbook
Acer aspire one zge netbook wont update windows
Check the TIME and DATE settings, Set Correctly, then you will be able to Update...
Oct 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
When i turned my emachine on it was making a funny noise and won't boot up
Sounds like your Hard Disk Drive is Bad and you will have to replace it this link will tell you how to install a hard drive
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Sep 08, 2011 | Acer eMachines 3502074 Netbook
When i turn my acer aspire one d255 netbook on it says no bootable device -- please restart system i need help please
Hi
It looks as though the laptop is not recognising the hard drive, there is no hard drive fitted or there is a hard drive but the OS boot record has been wiped ( I know this sounds obvious but some people buy these 2nd hand only to find the hard drive was removed)
You need to check the hard drive is present by booting to the bios screen it should "see" the hard drive attached. If it is present, then you have a problem with the OS or a damaged hard drive. I think its DEL or F2 or F10 to access the bios, not certain.
At this point, you need to attempt to reinstall the OS, as this does not have an optical drive, you will need to obtain a USB Optical drive, go into the bios and see that it is recognised as a boot device. Do not worry about setting the boot order, the Bios will locate the rom as a boot device.
Attempt a start up repair, ie: wait until the installer looks for a previous installation of windows (if one exists) then allow it to install a repair installation. If it does NOT find this, you will need to doa full install. If at this point you have files you need recovering, a strip down of the netbook and removal of the hard drive will be necessary. You simply then get someone with a computer to jumper your hard drive as a slave and recover the files you need, as a full install requires the hard drive to be fully wiped.
Replace the hard drive after you have done this and proceed with the full reinstall
You can use a USB boot device, but to do this you will need to have access to another computer to make the boot installer:
here
Aug 02, 2011 | Acer Aspire One D255-2670
On start up, netbook gives "Disk Read Error. Press
1. See If there is something attached to the computer (printer, usbo devices, phones etc.) . If there is disconnect it
1. Try checking the BIOS make sure the first boot device is the hard drive save the changes and restart the computer
2. If that fails. Try restoring the BIOS to its factory defaults
4. If you can't still boot up. try do a Operating System Reinstall
5. If everything else fails Replace the Hard drive
Thank you for Choosing
Jul 03, 2011 | HP Mini 1000 Netbook
I recover the operating system with hp recovery system, but once completed and restart the netbook, my hp mini 2140 never managed to come in and just boot windows back and forth. then I did the hard disk...
Go into the BIOS by pressing f10 when powering on the laptop.
Go to System Configuration and choose Device Configuration
Scroll down to SATA Native Mode and disable.
Press f10 to save configuration. The computer should reboot and press f9 to select boot device.
See if the 160GB hdd is now showing as an option. If it is then you are in luck.
p.s: You may need to update the BIOS to the latest if it still does not show up for you.
Mar 01, 2011 | HP Mini 2140 Notebook
I need to restart the netbook to go back to factory settings
You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
Jan 24, 2011 | ASUS Eee PC 1000H Laptop
Boots only to bios settings, then blank screen after save and exit. will not take a cd boot.
Hello, since it can boot to bios setting, then have you try configuring the boot order,the cd drive should come first,after that your hard disc, if the hard drive comes before the cd rom then it would not recognise it. Change the settings and Save this settings, then try to boot from the cd again, if this does not work then i am rest assured that your hard drive has a problem,and you need to find solution to it by getting a new one. cheers Regards
Dec 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi, my disk drive on my samsung r370 is making funny noises and is not recognising any disks?
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
or
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 16, 2010 | Samsung Computers & Internet
Error Loading operating system
CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
Dec 31, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
HP Mini 1000  Netbook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
