Question about Canon NP 6545 Copier
When im making copies it will run off 4-5 pages and the jam up, i keep un jamming it and it keeps happening any ideas whats wrong?
  • Canon Expert
  • 270 Answers
Sounds as though the feed rollers for that particular paper drawer/cassette is in need of replacement.
Posted on Jun 21, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Every time I go to copy the paper gets jammed going into C from A. I have pulled out the A drawer and pulled the jam out of C numerous times and it keeps happening. What do I do?
Make sure the machine has toner. Sometimes running out of toner can cause jams. Otherwise make sure there are no tiny scraps of paper lodged anywhere. The tiniest piece can cause a jam. Also, make sure all the sensors are clean (they look like two little eyes). Make sure your paper tray is set to the right size and direction of paper if your copier has that setting - it is a green dial in the paper tray. If you've checked all these things you'll have to call your service tech because it may be a bad sensor or something else.
Mar 04, 2011 | Office Equipment & Supplies
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
The fuel cutoff switch appears to be jammed or not able to manual
It is not tripped if the red button is pushed down. The switch might just be defective. How many wires are going to the switch? And what colors are they?
Mar 12, 2009 | 1992 Ford Escort 4 Door
Paper jam indicator keeps appearing and there is no jam.
SOMETIMES THE PRINTER WILL READ THAT IT HAS A JAM IF SOMETHING LIKE THE INK ISNT CLICKED IN TIGHT OR SUCH. IM SURE YOU MIGHT HAVE TRIED UN PLUGGING IT FROM ITS ACTUAL POWER SUPPLY BUT IF YOU HAVENT I WOULD TRY THAT, IT COULD RESET THE WHOLE THING. IF THAT DOESNT WORK I WOULD JUST GET THE PRINTER IN GOOD LIGHT AND OPEN ALL COMPARTMENTS, THERE COULD BE THE SMALLEST PIECE OF PAPER JAMMED SOMEWHERE YOU CANT SEE OR WOULDNT EXPECT THERE TO BE ONE
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
Paper Jam
it maybe the paper......make sure your paper is laser print paper and right thickness....
Apr 30, 2007 | Brother HL-2040 Laser Printer
Canon NP 6545 Copier Logo
23 people viewed this question
old marine
old marine
